scotlan wrote:
Thanks for your patience and persistence!
OK I ran the engine for 5 minutes
No fans
Temp gauge barely moved into the first quadrant. That is the needle was at a quarter of the first quarter.
Looking at the readings they also look strange to me
Fredjohn wrote:Sorry can't open this version either (1pm no 2)![]()
The file should be named: Monday 1 pm no2.zip
by Simon_P » Mon 21.10.2019, 18:10
The fault may be an old one before you buy anything disconnect the battery for 10 seconds to clear any faults, then scan again and check.
try sending the file by email
Rambo wrote:You should get this 12 code 3 times in succession then any fault codes thereafter ie 15 low coolant temp, 41 CAS/HES sensor etc..) if any faults have been stored
If there are no fault codes stored you will keep on getting the 12 code flashing
GeoffSmith wrote:CTS is the Coolant Temperature Sensor.
Simon_P wrote:Coolant Temperature Sensor - see the wiki top left of the screen.
scotlan wrote:I read the notes on this and it says see CTS Write up. Do you know where I can find that?
Rambo wrote:But before you disconnect the battery, try the simple paperclip test. If its a faulty CTS it should show 14 or 15
Then disconnect the battery to lose any stored fault codes as Simon suggests and then do your Elanscan
PS just curious to see what fault codes are stored before you start from scratch
