bad echo
bad echo
Postby ratman » Wed 27.06.2007, 16:46
my elanscan is used to write "bad echo (sent:F45601B5)" when the car is connected with the engine running. what does it means????
Lotus Elan S2 n°538
ratman
Postby rip » Wed 27.06.2007, 17:03
I ran Elanscan for the first time yesterday and got the same.
I ignored it and got a sensible set of readings.
May be it is just its way of telling you that the ECU is alive?
Postby ailwyn » Wed 27.06.2007, 20:18
Bad echo happens when elanscan doesn't hear it's own request for data from the ECU.
This could be due to:
1. Com Port not set up correctly
2. Cable not secured properly at either end
3. Dodgy cable (perhaps Geoff is losing interest) :-D
4. Knackered ECU
If you are only seeing this once or twice, that's normal, sometimes the message fails, and Elanscan should be logging a fair amount of data.
If the list of Bad Echo messages fills the message window and no data is logged, please see points 1-4 above.
Ailwyn
Return to ElanScan
