Elan Scan help, please help
Postby Stereomic » Thu 30.08.2007, 20:58
Hi,
Can someone tell me what i need to use Elanscan and where i get it?
Instructions for the hard of thinking would be a big help
Feel the burn
Stereomic
Postby paulrwebster » Thu 30.08.2007, 22:43
First port of call has to be the For Dummies book.
Seriously though, you need a cable (have a word with there's only on f in Geof Smith),
software, http://members.lycos.co.uk/mcnica01/M100_ALDL.html
and a laptop.
paulrwebster
Postby tigerdog » Thu 30.08.2007, 22:57
:clap: :clap: :lol: :clap: :clap:
Postby GeoffSmith » Thu 30.08.2007, 23:26
And thanks to Gary's legendary negotiating skills, I am offering a free interface with every book sold! :-D
Postby Stereomic » Fri 31.08.2007, 00:29
Fantastic,
Geoff, can you "hook me up"
Feel the burn
Stereomic
Postby GeoffSmith » Fri 31.08.2007, 07:53
I'll stick you on the list - and it won't be as much as £75, that price is reserved for Gary. :lol:
Postby Stereomic » Fri 31.08.2007, 17:31
Excellent, thanks
Feel the burn
Stereomic
T-Shirt
Postby DeanG » Mon 03.09.2007, 18:10
I think this would make a great T-shirt.
DeanG
Re: T-Shirt
Postby tigerdog » Mon 03.09.2007, 18:33
DeanG wrote:I think this would make a great T-shirt.
:offtopic: At the risk of completely hijacking the topic, I found several places which will make custom t-shirts in single units: http://www.customink.com/ and http://www.zazzle.com/ seem easy to use and reasonably priced. I haven't used either, but it might be easier than trying for a major group buy.
Postby tigerdog » Mon 03.09.2007, 18:40
Now back on topic. I'm a newbie to Elanscan myself, but I was able to get it running under Windows2000 on a very old Toshiba laptop. I toyed with making my own cable but after discussing with Geoff, I opted to pay the gentleman for his research and handiwork.
Once the laptop is booted and the cable plugged in, running ElanScan is pretty darned intuitive. On the other hand, interpreting the results is best done through posting to the forum and relying on the skills of others. To me, interpretation seems to be right up there with reading tea leaves and predicting the future in the foam of one's ale (...scrying in your beer.)
Postby rip » Mon 03.09.2007, 20:12
I am trying to learn how to interpret the traces though. I feel that it is important to log engine performance when it is running properly. It does not cost anything and they come in useful when problems arise.
Postby Enright » Tue 04.09.2007, 00:06
It sounds like you're getting the hang of it too Rip, especially if you're experimenting with different fuel types.
It's also worth doing Elanscan runs without ever going anywhere, and sometimes without even starting the engine!
One of the first issues I found with mine was that I was only getting 90% throttle.
It was of course due to a slack throttle cable, but tightening it by the right amount to ensure I got full range of travel was perfect for Elanscan. A 10% performance increase for free - thank you very much! :D
What I'm getting at though is that you need to bear in mind that the numbers in front of you usually only lead you to ask more questions, and then you need to find out what the messages actually mean.
Postby rip » Tue 04.09.2007, 08:19
Never thought of that. Will give it a go. The 'engine off' one sounds particularly interesting.
I have not drawn any useful conclusions from this research.....yet. I need to learn more about what to look for.
Postby Enright » Tue 04.09.2007, 12:39
The last example (calibrating your TPS) was an ideal "engine off" situation. In fact it's what I'd recommend for that particular sensor.
An Elanscan run from stone cold, leaving the engine idling until the fans start to cycle is also useful, as you can check your temperature sensors, thermostat, fan switch and even the fans without forward motion varying the rate of cooling.
Er, and that was about the limit of my talents in THAT department (other than the blindingly obvious)!
Still, gives you something to work from...
Postby GeoffSmith » Tue 04.09.2007, 12:44
Paul Watkins did the definitive checking the fans run. Maybe Dave Speck will do a video one day.
I was hoping to get some knowledge into the Wiki on this but I'm too busy at the moment I'm afraid. If anyone else would care to start it though........ :poke:
Postby ESM » Wed 05.09.2007, 10:29
Geoff, Just checked out your website. It looks strangely familiar...
ESM
Postby GeoffSmith » Wed 05.09.2007, 12:44
ESM wrote:Geoff, Just checked out your website. It looks strangely familiar...
Took your time!
Return to ElanScan
