post PECO Mountain chip Scan....needs decifering
Postby mickmick » Tue 26.02.2008, 23:18
As it says on the tin
i have fitted a PECO and one of ESMs chips and done a run
was a long run, and at night on busy-ish roads so couldnt do any 30-70 runs, i just want to know for now if it looks like all is running right in my engine with the latest mods.
cheers for any answers Geoff or Alan (hint hint) :-D :-D :-D
regards
Mick
now i have one, i just want to keep tinkering with it!!!!!!!
sorry mum :(
mickmick
Re: post PECO Mountain chip Scan....needs decifering
Postby GeoffSmith » Wed 27.02.2008, 00:16
mickmick wrote:cheers for any answers Geoff or Alan (hint hint) :-D :-D :-D
Answers without a log? :shock: We're good. But we're not that good! :lol:
Postby abmunro » Wed 27.02.2008, 00:19
Use the force Geoff!!!! :smt065
abmunro
Postby GeoffSmith » Wed 27.02.2008, 00:33
Postby mickmick » Wed 27.02.2008, 02:36
:oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops:
sorry mum :(
mickmick
Postby rip » Wed 27.02.2008, 09:22
Firstly:
I have not looked at your log file, although I probably will later.
If I had, I am not experienced enough with reading Elanscan to give you an answer very quickly.
Did you do a scan before the mods as well? It would be interesting to see the differences.
Postby mickmick » Wed 27.02.2008, 09:26
yeah, there are some runs i did a long time back and some i did a couple of months back somewhere on this part of the forum
i might trawl thru it and group them all together if one of the pro's decides its needed (i cant spell nessecarry)
sorry mum :(
mickmick
Postby rip » Wed 27.02.2008, 10:04
Ok, a couple of things to look for:
The chip should give you more boost, which you should be able to see quite easily.
The exhaust should give you more power at high revs, but not have as much effect down low. Plotting power v rpm for how it was then how it is should reveal a difference here.
I have not got Elanscan with me :shock: , otherwise I would take a look.
Postby mickmick » Wed 27.02.2008, 11:10
ok, going to try and get all my scans together and have a looksee
sorry mum :(
mickmick
Postby mickmick » Wed 27.02.2008, 11:21
my scans for comparison, pre PECO and ESM chip x 2 and post upgrades
sorry mum :(
mickmick
Postby GeoffSmith » Thu 28.02.2008, 00:05
Sorry Mick, I haven't had time to look at them. And you needn't have loaded the others, I've still got copies! (sad git, I know)
I'll take a look when I've got a bit of spare time but in the meantime, why not have a go Rip? :poke:
Return to ElanScan
