by hilda » Sat 01.03.2008, 13:22
Hi once again.
I seem to be having problems after the winter lay-up.
Does anybody know an expert with the diagnostic equipment to check the engine/fuel system electronics ? The garage who normally look after the car are baffled but think the problem lies in the fuel metering,perhaps a failed sensor.
1990 white elan
hilda
by Sy V » Sat 01.03.2008, 13:35
Sounds like a problem for Elanscan, John.
Have a shuftie in that area of the Forum.
- LEC Godfather
by rip » Sat 01.03.2008, 14:56
Sy V wrote:Sounds like a problem for Elanscan.
I have the tools and a little knowledge.
Seriously, I have Elanscan but am still learning how to interpret the results...and am only about an hour away from you.
More help is always available once a log file has been captured & posted on here though.
Jack.
by GeoffSmith » Sat 01.03.2008, 15:34
Has Ailwyn been moving threads again? 'Part Cross-Reference'
I started to tell an interesting story to tell about sensor failure but it was off topic I'm afraid.
- Kitty Fiddler
by hilda » Sat 01.03.2008, 17:52
Hi
Thanks Jack
The engine is now completely dead. I take it that Elanscan needs a running engine to work ?
1990 white elan
hilda
by GeoffSmith » Sat 01.03.2008, 17:58
hilda wrote:The engine is now completely dead. I take it that Elanscan needs a running engine to work ?
John, it will report back vital sensor information even if the ignition is not switched on. Any one of the sensors may be the reason for non starting.
- Kitty Fiddler
by clemo » Sat 01.03.2008, 21:46
do you have any more information than that?
do dash lights come on?
can you hear the fuel pump turn over?
have you tried the inertia switch ( by the battery)
has the immoboliser locked you out?
thinking.......
clemo
clemo
- LEC Administrator
- Location: TORQUAY Devon. Cream first then Jam obviously.
by hilda » Sun 02.03.2008, 14:21
Thanks for the replies.
The engine was difficult to start & when running, especially at low revs, was very rich. The engine check light was off & all readings were normal. There was also a throttle delay.
It now won't fire at all.
Fuel pump working & as far as I can tell immobiliser working as normal.
1990 white elan
hilda
by Monty » Sun 02.03.2008, 14:36
hilda wrote:engine check light was off & all readings were normal.
Does that mean u did the paperclip test?
The next thing is to see if your getting a spark, it`s possible it could be the HALL (£20 from Lotus sale) inside that CAS
http://lotuselancentral.com/repair/cas.htm
- Chunder King!
by hilda » Sun 02.03.2008, 17:51
Thanks - no I haven't done the paper clip test yet but will do as soon as I can.
1990 white elan
hilda
by rip » Mon 03.03.2008, 09:01
No, it just needs the ECU to be alive.
by hilda » Mon 03.03.2008, 17:36
I've now done the paperclip test & the only code that it threw up was 12-no fault.
I've also checked that there is a spark which there is
Does elanscan do more than the paperclip test?
1990 white elan
hilda
by Candles » Mon 03.03.2008, 18:06
Yes, it tells you the outputs of all the sensors, hence you can see if something is weird. I would go down the more traditional route though initially: Spark (done), fuel?, etc etc....
Candles.
Candles
by Monty » Mon 03.03.2008, 18:10
Yes the Elanscan is more detailed.
I pressume that the ECM is ok since you can get in to service mode, you did read the codes correctly, ie the 1st 3 codes will show 12 and only then will it show an error code (thats if you`ve got one)
Might be worth replacing the HES in the CAS as it`s a cheap replacement
- Chunder King!
by GeoffSmith » Mon 03.03.2008, 20:31
Monty wrote:Might be worth replacing the HES in the CAS as it's a cheap replacement
But that failure would normally throw up a code 41.
For no better reason than I had very similar symptoms on another car, I'd suspect the coolant temperature sensor - ElanScan would highlight this problem for sure though. If you want an
interface, I have some made up and could get in the post to you tomorrow if you let me know your address.
Geoff
- Kitty Fiddler
by Monty » Tue 04.03.2008, 00:18
geoffsmith wrote:Monty wrote:Might be worth replacing the HES in the CAS as it's a cheap replacement
Geoff
Not always
- Chunder King!
by rip » Tue 04.03.2008, 10:39
John,
What is your next move with this?
If you are going to try diagnosis with Elanscan, it may be helpful to also scan a working Elan under identical conditions (ie. engine off, cold, ignition on etc). That way you will have a baseline to compare against.
by clemo » Tue 04.03.2008, 19:44
rip wrote:Sy V wrote:Sounds like a problem for Elanscan.
Jack.
hilda i would be getting a pack of beers in the fridge and then calling
super rip
clemo
clemo
- LEC Administrator
by hilda » Fri 07.03.2008, 14:44
Hi
The saga continues.
I took the plugs out & cleaned them, number 1 plug was quite wet & all were sooty.
The engine started then died after a few minutes. It will now only start if the throttle is fully open.
I took it for a run & it misfires across the rev range.
I've checked all the connections I can see & done a visual check on the visable vacuum hoses. All seem ok.
1990 white elan
hilda
Return to ElanScan
