Galsia's ES Run - 28.03.08
Postby ailwyn » Mon 31.03.2008, 08:28
For analysis and comments
Postby Galsia » Mon 31.03.2008, 20:49
Galsia
Postby Galsia » Wed 02.04.2008, 20:06
Galsia
Postby GeoffSmith » Fri 04.04.2008, 18:33
Galsia wrote:Did anybody have a chance to look at this yet? :)
Go and fix your lights, why don't you! :D
Postby Galsia » Sat 12.04.2008, 13:30
Galsia
Postby ESM » Tue 22.04.2008, 21:22
The log is pretty unremarkable. The boost is obviously above normal hitting 0.75bar just below 5000rpm. Everything I can see suggests the engine is in a good state of tune and is running well.
ESM
Postby Doug » Wed 23.04.2008, 03:53
Galsia wrote:I asked for a scan because I have sneaking suspicion that a previous owner has fitted a superchip. I'm thinking of getting an everest chip.
Thanks guys.
I hate to speak for Alan(ESM), but I suspect the ONLY way and a simple way to know if the chip has been altered is to do a "PROM Dump" (using ElanScan) and send the file to ESM and he can check it to see if it is altered . . .
Postby GeoffSmith » Wed 23.04.2008, 07:34
Doug wrote:I hate to speak for Alan(ESM), but I suspect the ONLY way and a simple way to know if the chip has been altered is to do a "PROM Dump" (using ElanScan) and send the file to ESM and he can check it to see if it is altered . . .
Postby ailwyn » Wed 23.04.2008, 08:02
I did try this at Donny, but it would not dump the whole file, and ES seems to bomb out after it hits 2 errors in the download. Don't know if this might be a sign that the chip has been tinkered with?
Postby Doug » Thu 24.04.2008, 19:10
well even with an altered soldered-on chip, you can still drop in a piggyback stock chip if needed to return the car to stock . . .
Postby CJ101KT » Fri 09.05.2008, 15:24
When I download this and open it in elanscan I can only see the one graph ... speed against time?
Is there a way to see the rest of the data collected or does it only record one set at a time?
CJ101KT
Postby GeoffSmith » Thu 15.05.2008, 19:41
Chris, all data is recorded. You've got to select what you display from the drop down boxes - see the Wiki.
Return to ElanScan
