by tigerdog » Mon 08.09.2008, 07:05
I've just found and fixed the cause of an EGR fault and I'd like to clear the code out of the ECU. The Lotus documentation says this can be done using the Tech1. Does ElanScan have a similar function? If yes, where? If not, I guess I can always pull the battery lead (where are the CNTL/ALT/DELETE keys on the ECU anyway?
by ailwyn » Mon 08.09.2008, 07:38
Doug,
I don't think ES has that facility, so pulling the battery lead will clear the code.
Ailwyn
- Forum Member
by tigerdog » Tue 09.09.2008, 18:01
Was hoping for an alternative, since pulling the battery also resets the "learned" A/F parameters and the ECU needs to be retrained. Oh well, it was worth a try.
by ESM » Tue 09.09.2008, 20:45
I could add it but there has never seemed much point as pulling the power is just as good. The 'learning' doesn't take a significant amount of time. Certainly a lot less than the programming would take!
ESM
by Monty » Tue 09.09.2008, 21:54
What about pulling the fuse for the ECM
- Chunder King!
by Dave Eds » Tue 09.09.2008, 22:00
EGR, ECU, ES, ESM , ECM.
Must be something to do with Lotus, they all begin wth.............
by tigerdog » Tue 09.09.2008, 23:22
Dave Eds wrote:EGR, ECU, ES, ESM , ECM..............
EIEIO
Return to ElanScan
