Disconnect your ALDL USB cable
Postby tigerdog » Tue 17.03.2009, 01:41
I parked Smaug last week, leaving the ALDL cable connected. Came out this afternoon to a flat battery. I remember there being a question as to whether the ALDL drew power when the car is off. I think the answer might be yes.
I'll modify and/or remove this post if I find some other obvious cause after charging the battery.
Re: Disconnect your ALDL USB cable
Postby lotos » Tue 17.03.2009, 02:40
The cable was plugged in - but the USB side disconnected, right?
lotos
Postby tigerdog » Tue 17.03.2009, 06:02
lotos wrote:The cable was plugged in - but the USB side disconnected, right?
Correct - plugged into the ALDL, disconnected from the laptop. If that's not the culprit, then either my battery is going, or I need to get one of those maintenance chargers.
Postby mnemonix » Tue 17.03.2009, 09:54
Or your boot light isn't turning off?
My battery was draining in a matter of days, and not charging properly when I took it out, so it definitely needed replacing, however the new one was still going flat. As it happens I have left my ALDL cable plugged in too. I'd be really surprised if that was the culprit but I can see it being an outside chance. For now I've unplugged a cable from the boot light to see if it fixes my issues.
Chris.
mnemonix
Postby GeoffSmith » Tue 17.03.2009, 14:14
I think you're barking up the wrong tree Tiger! You have an optically isolated one as well which was designed to be left in-situ. I did have some random flattenings but now I'm pretty sure they were due to an intermittent alarm problem. Boot light is a possibility or maybe the battery is going off - best take it for a thrash every day and make sure it's well charged. :twisted:
Postby theelanman » Tue 17.03.2009, 16:48
ah.......Id never thought of that......
if I didnt use my car fo a couple of weeks I always had a flat battery......
Id checked the boot light and that was ok....checked some other possibles too, to no avail....
however Ive had the ALDL cable plugged in since I got the car......routed the USB end through and into the glovebox for easy access and use....had never even thought that may be the culprit :oops:
cheers for that one doug....
I'll go and unplug it later :)
chers
G
Postby Specky » Tue 17.03.2009, 19:13
Doug,
I've left mine plugged in for months, cos Geoff said he did... :roll: (No effect, parked up for weeks at a time)
The only thing was a couple of tiny spots of rust on the USB end...
Postby dapinky » Tue 17.03.2009, 20:51
I don't know if it makes any difference, but i've got the serial plug version, and it's been plugged into the aldl socket since i got it, no problem with the battery.
Postby GeoffSmith » Tue 17.03.2009, 20:59
Specky's and Pinky's are both mine (I'm pleased to say) but I'm not sure about Gareth's - is it one of Alan's Gareth?
Postby theelanman » Tue 17.03.2009, 21:21
GeoffSmith wrote: but I'm not sure about Gareth's - is it one of Alan's Gareth?
yes it is:)
Return to ElanScan
