Help needed ECU - Solved
Postby Falco » Thu 27.08.2009, 19:46
Can sombody please help me analyse this file. This my first trial of ElanScan :D
There seems to be some trouble with the Turbo
Elan 90 white
Elan 91 Yellow
Falco
Re: Help needed ECU
Postby rip » Thu 27.08.2009, 21:50
According to the log file, you were jumping on & off the accelerator pedal without going more than halfway.
Unless that is the case (which I doubt), it looks like your throttle position sensor is faulty.
Re: Help needed ECU
Postby Falco » Fri 28.08.2009, 18:17
Hi´ Rip,
thanks for the reply. Just to make sure I have just today changed the TPS with another (testet), and I still have the same problem.
It´s like it is chocking/drowning when I floor the pedal, or when I give so much trottle so the boost is going over 0.2.
By the way there is a lot of sod in the exhaustgas
I have brand new sparks, leads and Hall/CAS.
I have just made a new ECU file (see attachment) (do I have a MAP fault ??)
Hope that you can help
Elan 90 white
Elan 91 Yellow
Falco
Re: Help needed ECU
Postby Falco » Fri 28.08.2009, 18:20
Here is the ZIP file :wink:
Elan 90 white
Elan 91 Yellow
Falco
Re: Help needed ECU
Postby saska » Sun 30.08.2009, 18:11
Falco wrote:Here is the ZIP file :wink:
You've got 34 knock events in just under 4 minutes. I'd be putting it in service mode and:
1) checking the timing (16 deg BTDC)
2) see if the timing stayed solid or wavered about
Tony
adw (at) saska.co.uk
saska
Re: Help needed ECU - still need help - please
Postby rip » Sun 30.08.2009, 22:52
Scan is still not showing full throttle. Can you not find a steep hill nearby hold the accelerator at maximum for a few seconds?
Also you mention dirty exhaust. As Saska suggests, this can be a sign on incorrect ignition timing.
Mine runs very poorly with timing set to 16btdc. Maybe this indicates a problem, but that's beside the point.
I also noticed your PROM id: 5849. I have never heard of it before.
Re: Help needed ECU
Postby tigerdog » Mon 31.08.2009, 04:38
And if it wavers about, what's the remedy? Rebuild CAS?
Re: Help needed ECU
Postby saska » Mon 31.08.2009, 08:38
tigerdog wrote:
saska wrote:2) see if the timing stayed solid or wavered about
I'd replace just the HES first but you might be right. IIRC Jon had a bent spline on his CAS and all his problems disappeared after replacement.
The other possibility is the ECU trying to compensate for some other incorrect input but I don't know enough about that to comment sensibly.
To the OP. I agree with Rip that a PROM ID 5849 is unknown, I've looked and Alan doesn't list it on the mountain chip site.
There are 800 logged faults and the only one listed as On is MAP low. So either there is a problem with the MAP Sensor or possibly a vacuum leak from the plenum/manifold though others may have better advice on the cause of the errors.
Tony
saska
Postby Falco » Mon 31.08.2009, 09:23
Thank you very much for all your suggestion. Tomorrow I will make sure that the timing is 16 degrees BTCT, i´ll check for leaks in the vacum to the MAP, and finanly I will try with another ECU unit with another PROM. Then I will make/upload an new file, an wait egerly your responces :P
Falco
Postby dapinky » Mon 31.08.2009, 17:34
When RIP says that you are not getting full throttle, just try this one.......
...Plug in elanscan, and turn on ignition - but don't start engine.
On left column, you should have:-
1) Throttle (set at 0%)
2) TPS Voltage (set about 0.35v)
now, put foot on accelerator pedal as far as it will go...
Throttle should go to 100% & TPS voltage to about 4v.
If it does, then you should get full throttle when driving.
If not, get an assisstant to operate the throttle lever on the throttle body under the bonnet (while you still have your foot on the pedal), and see if there is any more movement available - if there is, then adjust your cable length to get full throttle opening with full pedal travel.
Now you should get 100% throttle on elanscan!
If you don't then the TPS position needs to be adjusted until you do - then it is in the right place!
The whole lot only takes a few minutes (I did 4 cars in less than 10 minutes when we were in the Isle Of Man) and will make a big difference if it was out to start with.
Postby GeoffSmith » Tue 01.09.2009, 21:47
Erik, as your MAP and TPS signals are both low, I think it is most likely to be the supply from the ECU - pin C14 is common to both and should be 5V. See the circuit diagram on the Wiki. It could be a bad connection (clean them), the TPS or MAP sensors may have gone wrong (disconnect the MAP and see if the TPS output changes when you do what Pinky says above) or it may be the ECU 5V regulator (you'll need a multimeter to check the voltage). With incorrect MAP and TPS readings, your car will most likely run like a bag of spanners!
The PROM ID is unusual - could you please send me a PROM DUMP (in ElanScan select File | Dump PROM to BIN...) and I'll see if Alan can shed some light?
Re: Help needed ECU - Solved
Postby Falco » Mon 07.09.2009, 06:53
Problem solved.
I changed the ECU, gave the wastegate some masage, adjusteded the timing, checked the TPS. What exactly was the problem I am not sure, but it helped - it´s now running like a clockwork. :-D
Thank you all for your helpfull input
Elan 90 white
Elan 91 Yellow
Falco
Return to ElanScan
