0-60 performance
0-60 performance
Postby KO6SY » Tue 04.05.2010, 06:46
Can ElanScan be used to determine the 0-60MPH performance? Or is the timing not accurate enough?
I would have thought that speed versus time would give the answer but so far I have not seen an Elanscan that even comes close to the 7 second specification.
KO6SY
Re: 0-60 performance
Postby rip » Tue 04.05.2010, 09:20
I can't remember how often it samples all the sensors but it should be less than 0.1 seconds & this should be often enough.
I just don't think many of us on here are bothered with 0-60.
Blue Bullet asked the question of 0-60 a while back & nobody gave an answer using Elanscan.
Postby Alan_C » Tue 04.05.2010, 10:11
I guess if you're tuning or setting timing, then it's a measure of how you're progressing? With the Elan being generally a turbo charged car (yeah, yeah, except the NA variant), 0 to 60 times will be slower compared to a non-turbo car. A better comparison of acceleration would be 30 to 70 or 60 to 90 times?
Alan_C
Postby GeoffSmith » Tue 04.05.2010, 13:06
It's only visible after you've started running but reducing the acquisition period to less than the default 100ms will give slightly more data - I can't remember what the optimum setting is (before you start getting comms errors), but its going to be about 70ms according to my fag packet.
Postby KO6SY » Tue 04.05.2010, 16:27
Thanks for the input. I have looked at a couple of Elan Scans including my own and see about 12 seconds which is not what the car is specified at.
I was doing this to obtain an indication of how well the "beast" was performing:)
KO6SY
Postby tweetdriver63 » Tue 04.05.2010, 16:52
How long's it been since you did all the normal tune-up type of things? It seems to me that on a Top Gear show a while back, they were supposed to modify a car to perform like a Mitsubishi Evo. IIRC it had about 70K miles on it, and the biggest impact they had on its performance was May doing basic tune-up/maintenance things, which brought its HP back to where it was supposed to be. They dynoed it before and it was down significantly from its rated HP.
I doubt that I could get the stated 0-60 time myself, even with everything working as advertised. I'm not that good, and I think conditions have to be perfect as well.
'91 Elan SE
'04 MB C230 Sport Coupe
'08 Mercury Mariner Hybrid
tweetdriver63
Postby KO6SY » Tue 04.05.2010, 17:12
Good point about tune up.
Car has just come back from garage after having the timing belt changed so I really hope they checked timing :)
Maybe I had better check this !
KO6SY
Postby John_W » Tue 04.05.2010, 20:19
Here's an old graph of mine from when Alan was developing the Everest chips a few years ago.
The runs were done on my car on a flat road as part of testing the earlier chips (V3 & V4). The new chips are better, but the graph still shows that even a standard car can do 0-60 in under 7 secs without smoking tyres or burning your clutch out (it was my car, and I've still got it).
As cutlea01 says, you don't see a massive difference in 0-60 between the different chips because it gets there so quickly the increase in turbo boost (once it cuts in) doesn't have time to make much difference. The real beauty of the Mountain chips is the 30-70 (or whatever) performance, where you can see marked differences from standard.
If your car can't better 7 secs, it's time to do some basic timing checks, plug gapping, and question if the cat's blocked.
[solid line = speed; dashed line = boost. Particularly in the 2nd gear portion of the graph, you can see the different boost characteristics of the old V3 & V4. Remember, these were development stages, so the ragged looking boost curve of the V4.0 was sorted in later versions.]
Postby KO6SY » Tue 04.05.2010, 22:45
John,
Great to see the graph - at least I can see it is achievable.. Some of the other ElanScans that I have looked at just didn't show this.
KO6SY
Postby GeoffSmith » Tue 04.05.2010, 23:10
Don't forget that a lot of ElanScan data is posted when people have a problem!
Postby KO6SY » Thu 06.05.2010, 06:55
I think I saw a post some time back asking for some "good" scans, this would certainly help some of us who are trying to make sure everything is working well. Does anything exist?
KO6SY
Postby ShaunM » Thu 15.07.2010, 10:16
I think Rip has a few good scans, I know he got some last year at the snetterton Lotus weekend. Will pm him...
ShaunM
Postby rip » Thu 15.07.2010, 16:05
I do indeed have several.
He is a scan of Shaun's S2 from Snetterton last year. It was running well.
Shaun.zip
& Nicowalker1's from the same event. This was also running well
Nick.zip
& mine from a couple of years ago. I recently had my Piper exhaust fitted & it the weather was cold. You can see the boost creeping until it hits overboost.
221108.zip
I hope the above are useful. I have several with various faults too. If you need enything specific, please PM me & I'll see what I can find.
Postby nicowalker1 » Sat 17.07.2010, 19:56
rip wrote:I do indeed have several.
Shaun.zip
Nick.zip
221108.zip
Rip minewas running like a bag of spanners... I had a blowing exaust and timing was jumping all over with quite a bit of knock... this was all pre service, new pecco, new timing, alternator, pas belts pully water pump ect ect.... it runs a lot better now. Will have to actually do a scan when its rod worthy
nicowalker1
Postby rip » Sun 18.07.2010, 11:06
Ok, so I've a memory like a goldfish. :D
Return to ElanScan
