How to connect up the interface
Postby stevebow » Thu 06.05.2010, 12:36
This may have been covered before but i couldn't find it :oops:
What's the order to connect the interface up to the car do you turn the ignition on then connect or should you connect with the engine running ?
thanks
stevebow
Re: How to connect up the interface
Postby rip » Thu 06.05.2010, 15:38
It does not matter.
It is not like shorting out the connectors to put the ECU into diagnostic or service mode.
Postby stevebow » Thu 06.05.2010, 16:49
thats easy then :D
stevebow
Return to ElanScan
