by paza1 » Sat 21.08.2010, 22:04
Could someone have a look at attached please? I don't think anything is wrong but would like some reassurance as I am not familiar with all the readings. Cheers, Mark.
Silver 1992 SE Turbo.
paza1
by GeoffSmith » Sun 22.08.2010, 20:52
Sorry Mark - I'm in sunny Beadnell, sat on the front overlooking the sea, hacking into someone's unprotected wireless router on my son's Mac so no ElanScan for me for a week! I'm sure someone will take a quick look for you.
Geoff
- Kitty Fiddler
by paza1 » Mon 23.08.2010, 00:19
Thanks Geoff, no hurry, have a nice holiday. I'd better explain that the data is taken from cold to hot ( not driven) so not a full set of readings. I can see the thermostat opening and the fans kicking in twice, all at correct temp. You can also see where I blipped the throttle twice.
Mark
paza1
by saska » Mon 23.08.2010, 08:22
paza1 wrote:I'd better explain that the data is taken from cold to hot ( not driven) so not a full set of readings. I can see the thermostat opening and the fans kicking in twice, all at correct temp. You can also see where I blipped the throttle twice.
Mark I had a quick look at the log and can't see anything amiss. No faults stored. The idle goes from 1200 down to 950 as it warms and you can see where the thermostat open and fans kick in. There are 12 knock events at the end which looks like when you switched it off so not anything of concern.
Tony
adw (at) saska.co.uk
saska
by paza1 » Mon 23.08.2010, 12:03
Saska, thanks for taking the time to have a look. I feel reassured now. Now that I can use Elanscan, I will take it for a run and get a full set of readings.
Cheers,
Mark
paza1
by rip » Mon 23.08.2010, 12:43
Logging data during an enthusiastic drive is not always the most useful data to have (although it often is).
Sometimes it is useful to have a log of the engine idling, maybe starting from cold. It can even be useful to have a set of data logged with the ignition on but engine stationary.
Return to ElanScan
