O2 sensor lean
O2 sensor lean
Postby Lotus54 » Sun 18.09.2011, 22:55
I just got the ElanScan working and learning.
I see an O2 lean 'error' set. When I did the scan and watching, it seemed to sweep pretty weep, not bottoming or topping. But the range seemed a bit odd.
I haven't even seen if there is a 'base' mixture setting yet, which if it was a bit lean could explain that.
Any thoughts?
(I captured it from the very hard start cold, but the software crashed so I don't have it).
I did see my temp was fine, so the sender, wiring or gauge is bad.
Mark
1978 Benelli 750 sei, 1972 Benelli 175 Enduro, 2018 Beta Xtrainer 300
Lotus54
Return to ElanScan
