ElanScan - help reviewing
Postby Paul Hague » Sun 09.10.2011, 21:25
Could anyone take a look at an ElanScan for me?
Got (three of four times) a momentary hesitation and CEL illumination on the way up to Prescott last weekend, but nothing on the way back or on a short trip today (which is where the scan is from). Nothing obvious to provoke the problem, just cruising along at steady revs.
I can see fault code 41 is stored, so I guess I should be ordering a new Hall Effect Sensor, but is there anything else that shows itself in today's scan?
13-oct-11.zip
Thanks in advance.
Paul Hague
Re: ElanScan - help reviewing
Postby saska » Wed 12.10.2011, 21:27
Paul Hague wrote:I can see fault code 41 is stored, so I guess I should be ordering a new Hall Effect Sensor, but is there anything else that shows itself in today's scan?
Can't see anything obvious on the scan.
Temps look good, EGR, secondary throttle are working, A/F ratio looks good -- down to 10.3 under high revs/boost. There are 2 knock events but no retard is applied so wouldn't worry.
Max boost is 0.67Bar which for a std 1499 is pretty close to spot on.
Think doing the CAS fault (HES) looks the way forward. Then see if the fault has gone.
Tony
adw (at) saska.co.uk
saska
Postby Paul Hague » Sat 15.10.2011, 17:17
Excellent. Thank you.
Paul Hague
Return to ElanScan
