Dave Thomas' problem at 4000RPM
Postby Dave Thomas » Sun 03.05.2020, 22:47
Dave Thomas
Re: ElanScan Interface
Postby Fredjohn » Mon 04.05.2020, 07:48
Dave Thomas wrote:I hope this works
BW
https://dl-mail.aolmail.com/ws/download ... 4rSSjwoc6v
This link asks me to sign in to an AOL mail account, which I don't have. Did you try to zip your .ecu file and attach it to your post?
Postby Dave Thomas » Mon 04.05.2020, 11:51
Once again, after login issues.....Zip file
It says uploaded file is empty .... lets see
Dave Thomas
Postby Dave Thomas » Mon 11.05.2020, 15:04
Posted this elsewhere on the forum, this is just a PDF of the elanscan data.
BW
Dave Thomas
Postby Dave Thomas » Wed 20.05.2020, 17:41
Thanks for help and advice so far. Now have half an hours data from a warm driven car still cutting out injerctors at around 4000 revs.
I would value any advice / suggestions from elanscan experts!
BW
Dave Thomas
Postby RonR » Thu 21.05.2020, 20:50
Hi Dave,
Looks like you have a problem with your Coolant Temperature Sensor - Fault Code 16 (CTS low) after 75.3 seconds + Coolant Temperature = -39 Deg C for the whole run.
Have a look on the Wiki Here for info on the CTS.
Edit: I see I've been beaten to it on the other thread!
Postby Dave Thomas » Fri 22.05.2020, 10:23
Thank you Ron
Am awaiting a replacement as it was registering a voltage to the single wire. I was getting 12V rather than the 5V it mentions in the handbook. We will see when the sensor is replaced.
BW
Dave Thomas
Return to ElanScan
