ELAN ALDL DATA STREAM SPECIFICATION
Postby MKTECH » Tue 12.10.2021, 00:02
Hello dear friends.
I'm looking for ELAN ALDL DATA STREAM SPECIFICATION
like this GM sample:
WORD BIT - DESCRIPTION - EQUATION
1 PROMISED (MSB)
2 PROMIDB (LSB) PROM = (N 1 *256+N 2 )
3 MALFUNCTION WORD 1
0 MALF CODE 24 VEHICLE SPEED SENSOR
1 MALF CODE 23 LOW MANIFOLD AIR TEMPERATURE
2 MALF CODE 22 TPS LOW
3 MALF CODE 21 TPS HIGH
4 MALF CODE 15 CTS LOW
5 MALF CODE 14 CTS HIGH
6 MALF CODE 13 OXYGEN SENSOR
7 MALF CODE 12 NO REFERENCE PULSES...
If anyone has to share I would be very grateful. Many Thanks!
MKTECH
Re: ELAN ALDL DATA STREAM SPECIFICATION
Postby BarryDalHerbert » Sat 30.10.2021, 03:44
I am at the very (very) early stages of investigating how a Raspberry Pi might communicate with our cars to produce ElanScan type output along with everything that happens whist driving (sort of like an aircraft's black box) as well as an alarm system, a music centre and whatever else occurs to me.
For this reason I have been poking around the Internet to find the same basic information as you have requested MKTECH, and just yesterday evening I found the two attached PDFs.
One came from here: https://MechanicBase.com/Trouble-Code/OBD1-Codes/
An the other from: https://BestOBD2Scanners.com/How-To-Read-OBD1-Codes/
I plan to hook my car up using ElanScan and see what data stream I can capture with the intention of trying to understand what I get. If there is anybody out there further down the path than my very first step, and they are willing to share what they have learned it would certainly save me a lot of time!
BdH
Tuross Head NSW Australia
30-Oct-21 13:44
BarryDalHerbert
Postby matts1972 » Sat 30.10.2021, 07:37
Hi BdH,
ALDL is great to work with as it will answer a “mode 1” request with the entire sensor data known to the ECU in one 64 byte size packet.
Feel free to use the code at ElanLogger.
It will provide most of what you require and will also answer some of your questions.
Good luck with your project!
Best regards,
Matthias
matts1972
Postby RonR » Sat 30.10.2021, 13:44
The Elanscan ini file contains the definitions of the fields you need, and the adjustments needed to turn the raw data into usable values.
The "Offset" and "Factor" adjustments are made in the form of addition & multiplication.
e.g. Here's the definition of Coolant temperature from the ini file:
Code: Select all
[Parameter 21]
Name=Coolant temp.
Position=6
Size=1
Offset=-40
Factor=0.75
FormatAs=%5.1f
Units=°C
Signed=0
Flags=0
Icon=25
and here's some code for getting it into usable format:
Code: Select all
byte DataBuffer[70];                      // Allow enough room for overruns
#define  Def_Offset     2                 // Offset from start of data record (-1 as array pointer starts at 0)
#define  DEF_CTS        6 + Def_Offset
   Calc_CTS = float(DataBuffer[DEF_CTS]) * 0.75 - 40;  // Calculate coolant tempature in Centigrade
#if defined(InUS)
   Calc_CTS = Calc_CTS * 1.8 + 32;                     // Adjust coolant tempature to Fahrenheit for US
#endif
   dtostrf(Calc_CTS,  5, 1, &CarData_ASCII[DATA_CTS]);  // Format Float as 5-byte ASCII
If a field is defined as Size=0 it's not in the ALDL data, but calculated by Elanscan.
Edit: The ini file is "M100 ALDL protocol.ini" and is usually in folder C:\Windows\
Hope this helps.
Postby BarryDalHerbert » Sun 31.10.2021, 01:48
Nice!
Thanks very much for your respective input Matthias and RonR.
I now have to actually extract my digit and get going!
BdH
Tuross Head NSW
31-Oct-21 11:48
BarryDalHerbert
Postby BarryDalHerbert » Sun 31.10.2021, 02:14
And thanks Matthias for the hyperlink to your ElanLogger project - which I somehow had managed to miss until now. :bonk:
BdH
Tuross Head NSW
31-Oct-21 12:14
BarryDalHerbert
Postby MKTECH » Sun 31.10.2021, 11:58
RonR wrote:The Elanscan ini file contains the definitions of the fields you need, and the adjustments needed to turn the raw data into usable values.
Code: Select all
[Parameter 21]
Name=Coolant temp.
Position=6
Size=1
Offset=-40
Factor=0.75
FormatAs=%5.1f
Units=°C
Signed=0
Flags=0
Icon=25
Code: Select all
#if defined(InUS)
#endif
Hope this helps.
Dear friend RonR, exactly this INI file I need. Because the Serial/ALDL communication I can do successfully through the microcontroller, I just need to identify the parameter referring to each byte.
Could you please share this file "M100 ALDL protocol.ini" because I couldn't find it in my windows.
Many thanks
MKTECH
Postby RonR » Sun 31.10.2021, 12:05
Some more details on the ECM ALDL protocol Here.
Not specifically for the M100 but a lot of GM ECUs used the same protocols.
Postby MKTECH » Sun 31.10.2021, 12:26
RonR wrote:Some more details on the ECM ALDL protocol Here.
Really what I need is only this .INI file, because I can already do the communication through the ALDL protocol, I just haven't been able to identify all the parameters of each Byte received yet, the .INI file would help a lot to finish this study.
TKS
MKTECH
Postby MKTECH » Sun 31.10.2021, 13:14
I'm find now the M100 INI file. Tks for tip
MKTECH
Postby Blaster » Sun 31.10.2021, 15:37
Have you installed Elanscan as this puts the ini file into windows. Sorry if I am stating the obvious.
Tony
1990 Lotus Elan SE 2009 Triumph Daytona 675SE
2012 KTM Freeride 350 2008 VW T5 4-Motion camper.
1995 Defender 300TDi 2012 Ducati Hypermotard
2018 AC Nitro 200 and Dudek Solo wing
Blaster
Postby MKTECH » Mon 01.11.2021, 11:54
Blaster wrote:Have you installed Elanscan as this puts the ini file into windows. Sorry if I am stating the obvious.
I find in: "C:\Users\MYUSER\AppData\Local\VirtualStore\Windows/'
MKTECH
Return to ElanScan
