Loss Of Power / New ElanScan File
Postby simonbuk » Sat 15.02.2025, 12:54
So I took my car to a dyno as it still didn't seem as well as it should've been. Dyno showed 126bhp and they said it was running richer and richer as the revs got higher.
I have done a new ElanScan file from cold start up for a few minutes of driving. It suggests my temp sensor is working, it boosts up to its maximum, what else should I be looking for ? I did perform a vacuum leak test a shortwhile ago (with mountain bike trye and pump!) which appeared ok.
Can somebody cast their eye over my file and see if anything shouts out at them please ? I've been told to check compression too which I will at some stage (when I have a tester).
SJB1.zip
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Re: Loss Of Power / New ElanScan File
Postby chrism » Sat 15.02.2025, 14:35
Yep EScan shows your air/fuel ratio keeps dipping down to the 'rich' values...
Could it be a dodgy/intermittant O2 connection I wonder? My m/plug behind the w/arch depinned - and there's also supply and (more importantly) earth O2 connectors that I might be inclined to check with a m/meter at the m/plug in the engine bay where you plugged your new sensor in
I've tried superimposing spark + temp data and there appears to be no connection - nor is it regular, which is why I'd (personally) suspect electrics first.
chrism
Postby simonbuk » Sat 15.02.2025, 15:26
That dip down corresponds to when I open the throttle (I think) so not sure it's a connection. But worth checking still though
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Postby KenS » Sat 15.02.2025, 17:34
Notice that the knock count is unusually high, it shows a burst of knocks on the acceleration. Traditionally I think this is a symptom of timing being too far advanced causing pre-ignition, and this would also explain lack of power, but looking at the timing plot does sort of indicate the base timing may be correct at around 15 or 16 deg, has the base timing been checked recently (needs to be in Service mode and procedure to reset the IAC followed)?
S2 M100 NMY #285
N/A 2010 Evora
KenS
Postby KenS » Sat 15.02.2025, 17:56
Just seen your other post which confirms base timing was checked good. Another cause of knocks is bad or low octaine fuel?
S2 M100 NMY #285
N/A 2010 Evora
KenS
Postby simonbuk » Sat 15.02.2025, 18:46
I have been putting the good stuff in it since i got it and the announcement that older cars should use the E5 stuff :smt023
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Postby simonbuk » Mon 05.05.2025, 16:26
Anymore ideas why I seem to be getting a high knock count ? Just been out for a run, sometimes lurches a bit at low revs , doesn't always seem to pulled hard throughout the gears, some slight hestitation.
0505sjb2.zip
Got some new leads and coil packs coming just in case.......
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Postby RonR » Tue 06.05.2025, 18:24
Had a quick look at your file Simon,
The knocks coincide with hard acceleration / fuel consumption. Maybe low fuel pressure causing lean mixture ???
I downloaded the raw data into Excel and plotted Fuel consumption (Engine speed * Injector duty * Injector pulse width) compared with Knock counter:
Postby simonbuk » Wed 07.05.2025, 14:15
Thanks for having a look Ron.
I assume there must be a fuel pressure regulator ? Or something that controls the fuel pressure in some way.
Maybe I need to buy another gadget to check the fuel pressure .
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Postby Tuga2112 » Wed 07.05.2025, 14:36
simonbuk wrote:Thanks for having a look Ron.
yes there is one. on the driver side of the engine, on the side, between the top cover and the intake plenum. if you follow the injectors you will find it easily.
id like to learn how you add somethign to test the pressure in there, i find the locaiton a complete pain to access. very interested in learning how someone can test that practically
Postby chrism » Wed 07.05.2025, 15:10
Restriction in the tank or fuel line? Blocked fuel filter, perhaps?
Just a couple of thoughts...
chrism
Postby simonbuk » Wed 07.05.2025, 15:18
chrism wrote:Restriction in the tank or fuel line? Blocked fuel filter, perhaps?
Yep - all possible things .....
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Postby FunElan » Wed 07.05.2025, 15:26
This thread mentions measuring fuel pressure: viewtopic.php?f=38&t=24751
Sadly...there's no valve on the fuel rail like many other cars, so it's a bit of a faff.
FPR is not hard to change if the system is de-pressurized, and if you're going to be doing the filter. Just have to remove the engine lift hook.
FunElan
Return to ElanScan
