ESM wrote:On ElanScan, the screen updates are much slower than the data capture (both are adjustable) this was specifically to maximise the rate of data capture as much as possible.
As to the garbage data - you didn't tick a menu item called 'Test mode' did you? This is a feature I put in to let me tests software features without connecting to the car - it literally outputs random numbers if its enabled.
By the way, TTS only know the format of the ElanScan data stream because they asked me...
Aurora40 wrote:So to sum up, the things I would look at if it were my car is:
- Is the physical timing too conservative?
- Are the secondary throttle blades opening?
- Is the O2 sensor shot? If this is cheap on your cars, I'd just replace and be done with it.
- Can the intercooler be improved, maybe it's something simple like leaves and road debris lowering it's effectiveness, or maybe that's just normal.
Ah, that's quite possible. It kept having errors connecting, and I was clicking on anything I could try to see if it would get working. "Test mode" sounds like it might test the connection or something, so that could be why it suddenly started "working".
ESM wrote:ElanScan logs every coms error it encounters - don't assume because the occasional coms error pops up that there is a big problem. A few errors just means a few dropped points - it is pretty error tolerant (so long as you've got the Moates device set to a 1ms latency). I should hide the log really, a high proportion of people think logging isn't working because of the odd glitch recorded in the error log. Unless its firing out several errors a second don't worry about it.
Alan ) Too bad I don't have an Elan to play with this program on anymore . . .
Aurora40 wrote:It was pumping the errors out fairly quickly though.
Doug wrote:Wow, glad you popped in here, Bob, cause I never heard of TTS before (Alan ) Too bad I don't have an Elan to play with this program on anymore . . .
I don't think there's too many people here who have finely analyzed their ES logs here to give a lot of feedback, Bob.
As an alternative, you could probably get people to send you their scans and you can cross check them as needed . . .
Or we can start a new area for detailed ElanScan discussions
geoffsmith wrote:If you've lashed up an interface to the ALDL socket, be careful how long your leads are. I've had problems maintaining a consistent connection when I was probing the interface with a 'scope - it was due to the increased capacitance of the extension lead.
That shouldn't cause you a problem then. I had a couple of feet of three core cable and it slugged the data line to death. Good luck next time.Aurora40 wrote:It is about 1.5" of copper wire we were using.
