TECH 1/1A
TECH 1/1A
Postby Dave S M100 » Tue 03.10.2006, 12:55
Guys,
I'm new to this site and didn't see much about info on the TECH 1 or 1A. I have a Tech 1A unit and the module for the Fed Elan and it works great.
I have both a FED Elan and a N/A Elan (non turbo). The Tech 1 does not work on the N/A and I have been unable to find out if there is a different module for the N/A, if so where to get one. Any help would be appreciated.
Thanks, Dave
Dave S M100
Postby Oliver » Sat 06.01.2007, 12:34
Hi there,
I am having the same problem. My N/A won`t talk to my laptop using a known good cable. The opinion is that the ECU may be subtly different.
My good friend Geoff is still trying to help me get it working.
Oliver
M100 N/A - No PAS
RenautSport Megane 275 Cup
MGF
Benelli 2C
Oliver
Postby Sy V » Sat 06.01.2007, 15:07
Dave & Oliver
This could be the missing link.
If a dedicated piece of diagnostic equipment like the Tech 1 doesn't work on the N/A using the Turbo software then it's not surprising that Elanscan-equipped laptops won't work either.
Postby GeoffSmith » Sat 06.01.2007, 15:46
Dave,
What a timely post, you're an absolute star.
Oliver has been having trouble with running ElanScan, a program developed by Alan (ESM or ElanScanMan as he is known here) and interface built by me with his N/A. You have just confirmed what I had begun to suspect, that the N/A is not compatible with the SE format ALDL.
I don't know if I can help you at the moment on the Tech 1 problem, but I now know where to start looking to try and decipher the N/A format for ElanScan. Once I have done that, I'd be interested to see if I can find any information on the Tech 1 and see if there is an easy solution (but it might be easier for you to use N/A ElanScan).
Geoff
PS Welcome to LEC by the way.
Return to ElanScan
