What have I got here then ?
Postby al » Mon 09.04.2007, 14:30
Hi guys,
I've recently started to think that my elan might enjoy a spot of mountaineering courtesy of Alan's finest, and since I was climbing all over the car anyway (to find an over-excitable microwave sensor) I thought I'd take some time to locate the ECU ready for when I get my order in...
.. so I was quite surprised to discover that my ECU is already missing the metal shielding for the memcal section and instead has a bunch of gaffer tape there.
The obvious question, then, is what do I have in there currently ?
And this is where I'm hoping you experts can help me out :D
I've attached the PROM dump I made with ES, and here's a bad photo I took:
Any ideas ?
al
LEC Bit Basher
Postby GeoffSmith » Mon 09.04.2007, 14:44
Interesting one Al!
Van Aaken don't list the Elan or Isuzu petrol engines so it may be a special. They claim to lift boost and change maps in the same way that Alan has, so I suspect he will be very interested to look at the changes.
Mine had a Superchip PROM, which just inhibited the fuel cutoff thereby allowing the MBC to operate. The good news is that you can still use a Mountain chip as the ony part of the original MEMCAL that is used is the hybrid circuitry to the right of your picture.
Geoff
Postby al » Mon 09.04.2007, 15:11
wow that was quick ! :)
Thanks for the info about Van Aaken, that was new to me... now I'm very interested to hear what Alan will have say about it !
Cheers !
al
LEC Bit Basher
Postby GeoffSmith » Mon 09.04.2007, 15:13
I've dropped him an e-mail.
Postby ESM » Mon 09.04.2007, 17:34
I'm away from base at the moment and so I can't check out the binary today. However, the ANXZ std suggests its a simple copy of a standard PROM.
Perhaps it had something more esoteric at some point in the past.
ESM
Postby Doug » Mon 09.04.2007, 22:23
probably not a factor and likely you can still drop the mountain chip in there which then would bypass this chip regardless of what it is and then you get the mountain fun
Postby GeoffSmith » Mon 09.04.2007, 22:26
Doug wrote:probably not a factor and likely you can still drop the mountain chip in there which then would bypass this chip regardless of what it is and then you get the mountain fun
Correct but a bit late! :lol:
Postby Doug » Mon 09.04.2007, 22:47
sorry, mister pres, just reaffirming it for him in perhaps a bit easier to understand way . . . :smt097
Postby GeoffSmith » Mon 09.04.2007, 23:03
Hadaway, ye divvent kna wor am taakin aboot? (<--that means, sorry I'm an ass!)
Postby Sy V » Tue 10.04.2007, 05:53
...well I'm not changing your Rank again! :wink:
Postby ESM » Thu 12.04.2007, 07:28
Now the handbags have been lowered I'll return to the point :P
I had a look and while it isn't the same as the stock ANXZ binary it hasn't got any table changes in anything significant (timing, boost, a/f ratio, etc). Since the checksum stored in the file and the one calculated from it are different I suspect corruption during the download (you need a pretty noise free interface or a few attempts to get a clean download).
ESM
Postby al » Thu 12.04.2007, 10:35
Awesome, thanks very much for taking the time to have a look at this for me, it's very much appreciated !
I'm happy to try repeatedly dumping the prom to see if I can get an error-free version if you're interested ?
Either way I suspect you'll be getting an order from me sometime soon (just after I have time to work out which chip I need :) )
Cheers !
al
LEC Bit Basher
Postby GeoffSmith » Thu 12.04.2007, 18:06
Al,
What about asking Van Aaken about what you've got - it would be interesting to compare it to the answer from Alan.
Geoff (handbag safely locked in the cupboard)
Postby al » Fri 13.04.2007, 13:34
Yeah, I did fire them off an email too to see what they'd say, I got a response this morning, it's a bit hand wavy but this is what they said:
Hi,
Thank you for your enquiry.
That is indeed one of our chips, it looks like it was supplied some time ago. Unfortunately, I will not have any records of this installation due to a recent server change.
However, I can tell you that your Elan will have gained approx 10-15bhp and 10% more torque, the rev limiter may have moved up by 500rpm too (this can vary by request, but we aim to keep it sensible).
it came from a sales manager there which probably explains the wavyness.
seems like there may still be something to be gained by looking at climbing everest...
al
LEC Bit Basher
Postby GeoffSmith » Fri 13.04.2007, 15:37
al wrote: it's a bit hand wavy
Testiculating - waving hands around talking bollocks! :-D
Return to ElanScan
