by tzicatl » Mon 16.04.2007, 02:42
Hi Everybody.
I downloaded ElanScan (Both stable and beta). I Tried to hook it to a Geo Storm GSI. It's been said the It's a mixture of Isuzu and General Motors so I am not shure wich kind of ECU is it.
Currently I only get the
- Code: Select all
Bad Echo (Sent: F4 56 01 B5
Rec: )
Message.
By what I've read in this forum this means that probably the hw interface is not working properly.
Currently I am using this one:
http://pweb.de.uu.net/pr-meyer.h/aldl.htm
Which is slightly different from the one that's recommended from the ElanScan web page.
Do you know if ElanScan can work in other cars other than Lotus Elan?
Thanks in advance!!!
duh?!
tzicatl
by GeoffSmith » Mon 16.04.2007, 07:10
Unfortunately, ElanScan is specific to the turbo Elan - it does not work yet with the N/A Elan. In a nutshell, the command word is specific to the Elan and the ECU is not responding. Your best bet would be to search for an "IsuzuScan" software. Your hardware should work however.
Geoff
- Kitty Fiddler
by Doug » Mon 16.04.2007, 20:27
there is some other program someone mentioned once that had an Elan-specific bit that allowed it to work. so even if the ElanScan doesn't work there may be another out there that could be adapted to the Geo, given it will be very similar to the Elan N/A engine -- computer is probably the same, spark tables could be a bit different but the differences would be minor
- LEC Founder
by tzicatl » Mon 16.04.2007, 21:13
Ok, thanks for the info,
Doug:
Do you recall the name of the software?
Thanks!!!
duh?!
tzicatl
by Doug » Mon 16.04.2007, 22:42
How did I know you'd ask!
So I did some soul searching and came up with your answer
CLICK HERE = DataMaster
I know nothing more, but maybe they can adapt it to your car??
- LEC Founder
Return to ElanScan
