Tuga2112 wrote:i take it you dont need any more help then ?
Blaster wrote:Tuga2112 wrote:i take it you dont need any more help then ?
No I have ordered from rock auto. Will find out how easy it is to get back in being slightly bigger over the bank holiday. I need to do an oil change so will change the filter while the alternator is out of the way.
Thanks for getting back to me.
dapinky wrote:When installed, the alternator was perfectly in the right place to be able to get to the bolts from the top to tension the belt without anything being too much in the way to make it work.
NoahR wrote:Blaster, did the new alternator from RA and the correct size belt all work well in the end, then? - With closed loop.
NoahR wrote:Interesting, thanks.
Removing the engine mount bolts took me hours last time, just due to the access, but perhaps I'll have the technique dialled this time, haha.
Just to confirm, you didn't need to swap the regulator - it worked out of the box?
