Grounded Point in Pedal Box for FED Elans?
Postby donsladek » Fri 07.08.2026, 05:16
Anyone know where the grounded connection for the instrument panel is in the FED Elans? Supposedly there is a bolt or fitting on the pedal box - any picture would be helpful. Trying to sort some electrical gremlins in rear indicators with LEDs and headlight doors.
Thanks!
Don Sladek
Calypso Red '91 #37594
donsladek
Re: Grounded Point in Pedal Box for FED Elans?
Postby peteoddcar » Sat 17.10.2026, 20:28
It’s a stud welded to the pedal box LHD should be on the right high up and hidden by heater ducting.
peteoddcar
