Washer warning light
Re: Washer warning light
Postby GeoffSmith » Fri 25.02.2022, 14:58
peteoddcar wrote:John
Don’t bin it - it might be repairable - Geoff??? :idea:
Don't ever throw custom modules away! Even if they're just used as a pattern for reverse engineering, they're useful and I have plenty of room in my lofts - in amongst the LEC heater stockpile.
Postby jgbff7 » Fri 25.02.2022, 15:39
It is safely tucked away in the Elan spares box.
It has 6 spades. None is identified, and I cannot find a circuit diagram for it. It is marked "BMI. made in the UK".
I am happy to make it available for reverse engineering.
And now for something completely different. To get to the relay holder I took the seat out and have used to opportunity to wet vac the carpet. Mmm, 25 years of use.......
M100 754/800
1991 SE
1992 Marcos Martina
jgbff7
Postby peteoddcar » Fri 25.02.2022, 17:53
If you have gone as far as taking the seats out then might be good to pop the sill trims off and have a look at the side members for any signs of rust at the area near the floor especially front and rear.
peteoddcar
Postby KenS » Thu 14.12.2023, 22:21
I had the same problem with the Washer warning light staying ON and 'cured' the problem by removing the red 'relay' module. As one of the winter projects, I have been looking at that removed module, removed the thin layer of rubber sealant around the base and then removed the red cover to reveal the circuit board. An eyeglass inspection failed to identify any mechanical issues around the components, but did show a crack around one of the relay pins solder joints and showed poor continuity with a meter. I reflowed each of the pin solder joints, refitted the red cover and reinstalled it in the car and all has been good, no warning light for the past week. So I think I have cured my bad module. The joints I reflowed are in the yellow circled area:
I was sure the pin in question was 3rd from top which is Pin 2 of the module, which from the circuits shown on the Lotus Forums looks like a ground, however their (Esprit) car side wiring shows no connection to that pin which is confusing, and I think it confused them, shown on their sketches:
And I don't think there are any Elan S2 wiring diagrams to confirm that pin 2 does/should connect to ground.
So bottom line is - I am fairly sure I fixed my bad relay by reflowing the solder joint on pin 2 of the washer warning relay/module. Would be interesting if anyone else with the same problem (that has been isolated to the module) has a look at those solder joints to see if this is common to their failed modules.
S2 M100 NMY #285
N/A 2010 Evora
KenS
