Connector plugs for Gemini Aquila alarm
Postby KenS » Sun 10.06.2018, 19:15
Hi, does anyone know the brand and type of connectors used on the Gemini Aquila 5160T alarm unit (used on the S2)? I have a Toad Ai606 ready to replace the original Gemini, was thinking that it would be easier if I could source the correct connector half to terminate the Toads wiring, making it a quick swapover for most of the connections. They look similar to Molex Micro-fit connectors, but those do not come in 3 row style (looks like they are split as a 3x3 and a 3x5 pin matrix). Any leads appreciated !
S2 M100 NMY #285
N/A 2010 Evora
KenS
Re: Connector plugs for Gemini Aquila alarm
Postby Saltire » Sun 10.06.2018, 20:02
Been there, tried to do that, got the T-shirt :?
I searched high and low without success. Eventually I labelled the wires going into the Aquila, cut the connectors off and used two new multiway connectors with new terminals soldered onto the wires. Somewhere - if I can find it - I have a conversion chart between the old Aquila wiring colours and the new Toad alarm.
It’s not too hard, but it is a bit of a faff
Postby KenS » Mon 11.06.2018, 21:23
Starting to think that changing the alarm is a job to put off for the winter when I can pull the dashboard in slow time to make access easier. Meanwhile I try to map out my exact connections, especially the black ones. Do you know if the Gemini ultrasonic sensors can be re-used on the Toad or do they need stripping out and swapped for ones supplied with the Toad?
S2 M100 NMY #285
N/A 2010 Evora
KenS
Postby Saltire » Mon 11.06.2018, 21:51
No, Ken, the Toad comes with its own ultrasonics which must be used. I also fitted a microwave and tilt sensors as options. Contrary to what the Toad instructions say, I fitted the ultrasonic sensors in the OEM locations. It’s a bit of a faff, because you have to remove the windscreen header rail and enlarge the holes slightly, but it can be done. I took the opportunity to add a dash cam power supply, a digital radio aerial and connectors for some extra LED lighting in the foot wells while I was up there.
You’ve reminded me to look out my notes of the connections - may save you a pile of time.
Postby Saltire » Tue 12.06.2018, 21:05
I’ve found my connection schematic, but it needs a couple of changes. Once they’re done - a day or so - I’ll PM it across to you. For obvious reasons, I don’t like to put details about the alarm systems on the open forums.
Postby KenS » Wed 13.06.2018, 21:53
Thanks Jonathan, any info will certainly be useful. One of those jobs that takes some courage to start !
S2 M100 NMY #285
N/A 2010 Evora
KenS
Postby Saltire » Thu 14.06.2018, 11:14
Hi Ken, you have an email with lots of details in it. Let me know if anything's not clear.
Postby KenS » Thu 14.06.2018, 20:29
Email received, many thanks Jonathan, a lot of useful info which makes the job a lot less daunting.
S2 M100 NMY #285
N/A 2010 Evora
KenS
Postby bodoballermann » Wed 06.07.2022, 07:41
Hi, having the same Probleme, has to replace the alarm box because I could not get any more replacement fobs.
I try to change to a newer Aquila model, could I pls have some Ideas about the cabling, otherwise a lot of work.
Greetings from the continent !
Calypso Red S2 #019
Elise Mk I 111S Type 72
bodoballermann
Postby KenS » Wed 06.07.2022, 15:09
Hi, checked that this is a bona fide request and find you have had your S2 since 2011, I have emailed some details that should help. Most of the info was originally provided by Jonathan, so credit and respect needs to go to him for putting it together. (Sorry Jonathan :bowdown: if I beat you to the reply).
S2 M100 NMY #285
N/A 2010 Evora
KenS
Postby Saltire » Thu 07.07.2022, 07:44
No problem, Ken, glad my scribbles have been able to help again :D
Postby kevin0507 » Tue 11.10.2022, 12:52
Good Afternoon
Recently purchased a M100 which has been sitting for many years !
Recommissioning was all going well until the key fobs stopped working, looks like the car has a factory fitted toad alarm. Question is there an alarm I can purchase to fit onto the wiring loom like the old unit ?
any help is much appreciated ?
Kind regards
Kevin
kevin0507
Postby Saltire » Thu 13.10.2022, 09:05
Hi Kevin
To the best of my knowledge, NO M100 Elans came with a factory fitted Toad alarm. It sounds as though you have an aftermarket unit - what year is your car?
As a first step, I would try new batteries in the fobs; Toad recommends they are changed every year, and that may well help. If not, we’ll need to think again.
BTW,it helps if you put your location in your profile (accessed through the user control panel link at the top of this page). You never know, there might be a member local to you who can help out.
