djwazza68 wrote:I am living in optimistic la la land?
MarkP wrote:Thanks Rambo, the issue is that it is physically broken between the top of the spring and the mast. In the photo I just pushed them together so perhaps that’s not clear from the picture. When I got the car it had many layers of black insulating tape wrapped around the join to keep it together, so cosmetically it was all black. But not straight and somewhat floppy. There is not enough metal left at the bottom of the mast to tap a thread into it to give it the strength it needs. I’m guessing that is how it was manufactured but years of fatigue destroyed that part of the mast and it’s just not there any more.
I do like your thinking though as my first thought was to solder the two parts together and then shrink wrap over the top but there is not a lot to solder to and I could see me arriving somewhere having ejected the mast off the back of the car on the way as the soldered joint failed!
Brit-Car-Nut wrote:Won't this one on eBay work?
https://www.ebay.co.uk/itm/Whip-Antenna ... 3301512475
It says it comes with an adapter stud of 6mmx6mm and 6mmx5mm but it would be easy to get a brass or stainless stud made that is 6mmx4mm.
If it will work but nobody will make a "special" stud, I can probably do it for you. I just need the correct size,thread pitch and length of each end and if it needs a small section without threads in the middle.
I don't know it it is too long or ugly looking, I just looked at the options on eBay.
Amazon UK might have similar options too...
djwazza68 wrote:I want to replace the entire aerial unit on my Elan and was hoping that there is a perfect aftermarket unit which is an almost identical replacement? Mine was replaced with a horrible chrome unit some years ago and doesn't seal to the wing properly.
MarkP wrote:Sorry about the thread hijack!
Saltire wrote:Mark (Bucks not Borders!)
Aerial mast in the post to you today, so try it out and see what you think.
When you receive the parcel, there’s an outer cardboard tube, then a wrap of corrugated cardboard, then a piece of white electrical conduit. The aerial mast is inside the white conduit! Can’t be too careful with the Post Office.
Please confirm safe arrival and let me have it back if it doesn’t fit for any reason (although it was taken directly off an Elan, so it should do).
Bank details are in the parcel if you need them.
Good luck
