How to remove the door speaker grills ?
Postby simonbuk » Mon 13.05.2024, 23:02
Do you have to remove the door cards to get behind the speaker grills ? Or can you grills/covers be prized out ?
Did have a search and looked at WikiLEC but couldn't find anything.
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Re: How to remove the door speaker grills ?
Postby TorqueHorse » Tue 14.05.2024, 04:42
You need to take the door card off, or at least you do if you want to retain the metal grille for reuse. But, FYI, I have my door card off right now, and I still don't know if I can take the grille out without destroying it. I might just mask the grille on the door card and spray it while attached.
'91 FED M100 -rolling resto
Postby simonbuk » Tue 14.05.2024, 07:47
TorqueHorse wrote: I might just mask the grille on the door card and spray it while attached.
I was thinking of doing the same !!
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Postby Tuga2112 » Tue 14.05.2024, 07:56
isnt it just bent metal around to hold it to the door card ? i think i recall seeing that on mine
Postby dapinky » Tue 14.05.2024, 09:16
The grille (on mine anyway) is just a bit of mesh bent to shape and pushed into the door card from behind (the spring tension of the material holds it in place).
Postby simonbuk » Tue 14.05.2024, 11:57
dapinky wrote:The grille (on mine anyway) is just a bit of mesh bent to shape and pushed into the door card from behind (the spring tension of the material holds it in place).
Just to confirm - Yes, its just 4 simple extra bits of the speaker wire bent back to keep it in place, accessed from behind.
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
