by French_elans » Thu 18.06.2026, 15:33
Hello,
a question about the main chassis earth point (the one at the RHD behind the seat).
is it easily reachable?
I would like to change it.
regards
French_elans
by peteoddcar » Thu 18.06.2026, 20:42
Yes. It routes to a junction box with 8mm std - plenty of similar cables available or I could make you one.
The negative terminal is a Ripaults part but it’s a very generic part.
peteoddcar
by French_elans » Sat 20.06.2026, 08:38
thank you for the answer and your proposition,
I find the scew,
do you know if the nut is welled on the chassis ? or is it necessary to access inside the chassis ?
regards
French_elans
by peteoddcar » Sat 20.06.2026, 21:22
Easier to fit a new battery connector to the existing wire - the chassis earth is difficult to access
peteoddcar
