by dave_ward » Tue 13.09.2005, 13:20
my elan is playing me up at the moment, the box (ecu??)behind the glove compartment has a mind of its own, when i drop the glove box and mess with the wires or just slightly move it, the engine runs perfect, let it go and it starts jumping or stalling, it only takes the deftest touch and its fine or vice versa, only found out that it was this as it was having one of its moments when i was getting something out of the glove box, shut it and it was fine again, is this very strange or is me,
my thinking is a loose wire, but which one?? or is the box knackered
dave_ward
- Tinkerer
by Sy V » Tue 13.09.2005, 13:41
There are two looms which end in multi plugs that go into the ECU - check that the plugs (which can be quite tight) are seated and clipped into place.
Also, check that the small earth wire that connects under one of the fastening nuts is tightly in place.
Where did you buy your Elan from...is it (or has it been) chipped? I'm not casting performance doubt on the chip...just wondering whether it [the ECU] has been removed and not reconnected properly.
- LEC Godfather
by dave_ward » Tue 13.09.2005, 13:58
had the car for 4 years, not been chipped, however i have always had a problem of this kind but its ok for 6 months and then for no reason it does it again.
will try what you suggest and see what happens
dave_ward
- Tinkerer
by dave_ward » Tue 13.09.2005, 14:25
okay! done what you said and took it for a drive, seems fine now except CEL is now on and will not let me go past 3800revs, is this limp home mode and if so how do i reset it
dave_ward
- Tinkerer
by Monty » Tue 13.09.2005, 14:36
u need to do a paperclip test to find the error code.
To reset disconect the battery for about 30 secs.
- Chunder King!
by dave_ward » Tue 13.09.2005, 15:37
strange all is well now, CEL is off, car is running perfectly again.
all i need to do now is fix the glove box catch which i broke while my anger was setting in, christ its difficult getting under there my back is in two
dave_ward
- Tinkerer
by clemo » Thu 15.09.2005, 11:56
its definatly NOT the lotus position!!!
glad you fixed it...
clemo
- LEC Administrator
- Location: TORQUAY Devon. Cream first then Jam obviously.
by timmo » Thu 15.09.2005, 17:21
clemof1 wrote:its definatly NOT the lotus position!!!
Back from honeymoon and mind already in the gutter. Good work feller!!
I wonder how much deeper the ocean would be without sponges.
timmo
