A lot of issues....
A lot of issues....
Postby Gista » Tue 04.10.2005, 15:06
Finally I've decided to repair all the issues as I can (unfotunately, as many of you could know, here in Italy is not so easy to find good mechanics and cheap spare parts), but I still need some help:
1) headlamp fix: my right motor don't work... I need the repair kit, I saw it available in an american site, but I wish to find it in UK, maybe from SJ ('cause I'll buy other parts from SJ), but in the catalogue I can't find it; what do you do in UK?
2) window regulator: I'll buy from SJ
CLIP, (Butterfly) GLASS to REGULATOR
WINDOW LIFT SWITCH (the button in the center console)
3) Speedo indicator: I'll buy speedo cable from SJ
4) fuel indicator: ...... mmmm ..... I don't know what to do!!!! My fuel indicator never worked!!!! However my fuel pump work fine, and my "pseudo" mechanic told my the problem is the floating switch inside the pump... what I have to do? I must change all the pump?
5) Check engine light: I think is the famous CAS.... i try to explain: when I'm driving and I'm stopping my car, if I use the engine brake, leaving the RPM decreasing slowly, the check engine light turn on and I must turn off my car, or my engine start to work very badly, knocking... Somebody thing that's the CAS?
I wish to tanks in advance everybody could help me, I hope to receive soon some hints.
Bye, Gianni.
Gista
Postby Monty » Tue 04.10.2005, 21:14
Think only AB motorsports does the repair kit for the lift motor
http://www.abmotosport.com/Elan_products.html
If u`r getting the engine light u need to do the paperclip test to get the fault code:-
http://lotuselancentral.com/repair/aldl.htm
Postby Gista » Wed 05.10.2005, 10:21
Monty, thanks for the hint about the ALDL test, my car is now at mechanic workshop doing this, I'll let you know what kind of error I'm having.
About the headlamp fix kit, I was searching for a dealer closer than in China or Korea... however thanks a lot.
Somebody know other dealers in Europe?
Gianni
Gista
Postby Paul.P » Wed 05.10.2005, 18:52
Gianni, your fuel gauge might not be working because the sender unit in the fuel tank might be catching on the side of the tank ?. When i had to drain my tank, i took the sender unit out of the top & it took 3 attempts to get it back in the right position. Hope it is this, as them sender units are not cheap, about £250 if i remember right ?
Postby Gista » Wed 05.10.2005, 20:54
Thanks Paul for your reply, unfortunately my mechanic told me the sender unit work fine, he told me the issue could be something electrical circuit related, could you agree? (obviously the circuit of the sender unit)
Gianni
Gista
Postby Paul.P » Wed 05.10.2005, 21:54
The sender unit is fully enclosed as i remember, what you could do is take it out of the petrol tank, reconnect it, lift the arm up & see if your gauge works, if it don't work, theres a good chance your unit is knackered & you will have to replace it. My mechanic told me my unit had had it, until i insisted he looked at its position within the tank , that saved me £250 !
Postby Gista » Wed 05.10.2005, 22:39
Ok Paul, thanks again for your immediate reply, I'll try to explain this to my mechanic and i hope he could be so able as your!!!! (saving £250!!!)
Bye, I'll let you know.
Gianni
Gista
Postby Gista » Wed 05.10.2005, 22:52
Looking better in other post, I saw Dimitri_GR had the same problem, and he changed the floater:
Dimitris_GR
Posted: 16 Dec 2003 08:20 Post subject: Re: Fuel gauge never going above quarter
[quote author=WillB link=board=help;num=1071151672;start=0#9 date=12/15/03 at 06:41:01]
Ooops, forgot to say, check the float part of the sender is full of air and not fuel! This was the problem with mine as it had a pin hole in the float. It filled with fuel and sunk to the bottom giving a false empty reading all the time.
[/quote]Been there!
It was the floater and the replacement part came from a simple part store for several euros!
____________________________________
I'll try to send him a message to see if he's still in the forum and if he could remeber who's the producer/dealer.
Gianni
Gista
Postby Fubar1764 » Fri 07.10.2005, 05:46
Gista wrote:Monty, thanks for the hint about the ALDL test, my car is now at mechanic workshop doing this, I'll let you know what kind of error I'm having.
Gianni
With AB Motorsports, you could contact WillB. I placed the order with him, and he had it shipped in from AB in Thailand. The AB cables are significantly superior to the stock. I would not hesitate to wait the extra few days or even the extra few lire to purchase those from AB Motorsports. Hope you found this helpful.
-Your "Jack" of all trades
Fubar1764
Postby Gista » Fri 07.10.2005, 09:57
Thanks Fubar for your hint, unfortunately I had the gear cable issue on 2002 and I'v fixed it buying the cables here in Italy, you can't imagine how much money I've spent for this!!!! I was stupid and newbie, for this reason I was gone in an official Lotus shop... the result: a pair (the dealer told me ho could sell only the pair) of cable 600 euros....
.... God bless Lotus Elan Central!!!!!!
Bye
Gianni
Gista
Postby delta » Tue 11.10.2005, 19:08
You don't need to have the repair-kit to do the headlight motors. The 3 small "plasticthings" can easely be replaced with 3 pieces of gasoline hose, diam. 13mm.
Have done this to mine, and it works just perfect. :!:
delta
Postby Monty » Tue 11.10.2005, 20:32
delta wrote:You don't need to have the repair-kit to do the headlight motors. The 3 small "plasticthings" can easely be replaced with 3 pieces of gasoline hose, diam. 13mm.
Thought it was the plastic cog that needs replacing :?:
