Blower Fan - follow up
Postby scottpegler » Fri 07.10.2005, 21:16
Many months ago (before the new site came online) I posted a cry for help because my blower fan, which has four settings, would work on only the third and fourth settings. I am posting this message to say the problem is solved...As it turns out, it was the blower motor resistor (part # A100P6033S, $38.75 from Dave Bean Engineering). I had checked all related fuses, pulled the fan, checked wiring. Finally, I pulled the resistor, which is located adjacent to the fan motor (easy to get to), and noticed two severed wires (resistor coils)...the culprit! Hope this helps someone else.
Scott
scottpegler
Postby Doug » Fri 07.10.2005, 21:51
glad to hear it is fixed, and that makes perfect sense
