Headlamp Pods
Headlamp Pods
Postby grahamec » Wed 19.05.2004, 11:52
Morning all<br>1-The pods on my S2 seem a bit reluctant to lift fully at times, are there lubrication points that I can lube ?<br>2- If I am to replace rear light bulbs which ones should I fit to have brighter lights.<br>Cheers<br>Grahame
grahamec
Re: Headlamp Pods
Postby Andy » Thu 20.05.2004, 04:16
Don't bother w/ the lube.  Sounds like the motor drive needs rebuilding.  There is a writeup on this subject.  As for the rears, wouldn't recommend the higher wattage bulb.  They tend to over heat and deform/discolor the plastic lens.
Andy
Re: Headlamp Pods
Postby nitroman » Thu 20.05.2004, 05:35
Grahame, here are some bright bulbs.  The running light of 8w makes a huge difference.  Bcuz it is a halogen it uses no more juice than a 5w incandescent!  The others truly light up the night.  I have used these bulbs going on 2 years now and couldn't be happier with them.  I suffered what Agent Smith talks about in my youth when I put always-on high-watt bulbs in vehicles.  But the reverse & brake lights just aren't on long enough to reach high-temps.  As to whether 8w can melt anything, I really doubt it.<br>Rear running/turn-signal:  <br>http://www.jcwhitney.com/webapp/wcs/stores/servlet/ProductDisplay?productId=324&catalogId=10101&langId=-1&storeId=10101<br>  <br>Backup #1156:  <br>http://www.jcwhitney.com/webapp/wcs/stores/servlet/ProductDisplay?productId=7837&catalogId=10101&langId=-1&storeId=10101
nitroman
Re: Headlamp Pods
Postby grahamec » Thu 20.05.2004, 11:35
Thanks for the replies< I'll do a search for the write up.<br>Grahame
grahamec
Re: Headlamp Pods
Postby Sy V » Fri 23.07.2004, 08:59
I have an intermittent (4 times since I bought the car) headlight pod deployment problem.<br>Headlights come on but pods don't even try to rise (same result via headlight switch or flasher stalk). Headlights failed to deploy when I set out for home last night, but (having hand cranked them up to begin journey) they operated normally on arrival home.<br><br>Suspect dodgy "pod delay module" relay or (worst case) "pod control module" itself...other ideas?
Re: Headlamp Pods
Postby grahamec » Fri 23.07.2004, 15:29
Sy<br>Wish I could help, alas can't but it sounds very much like the problem I had, which has self fixed for now. Hope ypu get it sorted.
grahamec
Re: Headlamp Pods
Postby Sy V » Fri 23.07.2004, 16:01
Grahame<br><br>From your original post I got the impression that you could hear the motors trying to lift the pods...My motors, when the fault occurs, don't even fire up, the circuits dead. Then, after an, as yet unconfirmed time, the "system" rights itself.<br><br>Lotus Biorythms again...
Re: Headlamp Pods
Postby grahamec » Fri 23.07.2004, 18:54
Sy<br>Do you sometimes wish you'd kept ones mouth shut  :-X well guess what, after reading your last post I went out to check and the passenger side pod's not working again and no sound from the motor :'(<br>But I do lerve this car ;D
grahamec
Re: Headlamp Pods
Postby timmo » Tue 27.07.2004, 20:11
Sy <br><br>I know you will already have done this but check all fuses and relays are secure and well pushed in place. My fuse that blew was the battery services one and it buggered all lift functions.
I wonder how much deeper the ocean would be without sponges.
timmo
Re: Headlamp Pods
Postby ab2cv » Thu 24.03.2005, 19:15
I'm going to bring this topic to the fore as I prepare to investigate a similar 'headlamp pod deployment' problem. My car started winking at me on the Saturday evening of Donington - drivers light pod comes up but the passenger one doesn't do a thing (no motor sounds or any funny noises). Then if I switch the lights off and back on again, both lamps come up as if nothing was wrong  ??? It did it again on the way back up the road on Sunday, except that time it took 3 attempts of switching the lights off and on to get the lazy passenger pod to rise. <br><br>Doesn't seem like a motor problem to me as when it works, it works fine. Maybe a loose wire or 'pod delay module' problem?<br><br>Alan
Yellow Esprit GT3
ab2cv
Re: Headlamp Pods
Postby Doug » Thu 24.03.2005, 21:53
play with the wires and plug-in harnesses to the pod module and see if it miraculously fixes it--lots of Elan problems come from little electrical contact problems.
Re: Headlamp Pods
Postby Sy V » Thu 24.03.2005, 22:17
Yep.<br><br>Just knock the centre of the module mounted on the bulhead.  I think you'll find it'll deploy.
Re: Headlamp Pods
Postby Doug » Thu 24.03.2005, 22:43
[quote author=Sy link=board=electronics;num=1084963958;start=0#11 date=03/24/05 at 13:17:25]Yep.<br><br>Just knock the centre of the module mounted on the bulhead.  I think you'll find it'll deploy.[/quote]<br>funny line if you read it just right<br><br>don't forget your showercap or you might find some new Elans to care for  ;)
Postby Rudz » Mon 18.07.2005, 07:28
Interestingly, I had a similar problem. Randomly, the headlamp pods would not lift up. No motor noises - not a headlamp motor problem cos I am familiar with headlamp motor problems having rebuilt them on a few occasions. This symptom only happens intermittently. The lights actually illuminate, its just that the pods dont lift. Sometimes, if I leave the light switch on & just drive away, it will lift up sometime during the drive - almost like an extended delay function - sometimes 10 seconds sometimes 5 minutes, sometimes more than that ! Anyone had similar problems ? I also realised that LOTUS has 2 similar replacement modules - headlamp pod delay module & headlamp lift module. Anybody knows the specific function of each module ?
Cheers ... Rudz
Rudz
Postby Sy V » Mon 18.07.2005, 08:11
No Rudz.
You have exactly the same problem. It's that bulkhead mounted unit and/or the wires going into it.
Change it and you'll not have the intermittent illumination but lack of erection problem.
Postby edhand » Tue 09.08.2005, 00:49
Is there still a writeup on the headlamp motors? There is a line on the repairs page but it is not an active link. One of mine has started acting up lately. The usual symptoms, excessive whirring and clinking and the pod not making it all the way up on its own.
Cudos on the site redesign for whoever was in on it. I really don't get in here often enough any more.
Thanks,
Ed
edhand
Postby Doug » Wed 10.08.2005, 03:49
Ed,
the new page isn't up yet, but here's the link to the old page.
http://www.lotuselancentral.com/lec/headlamp-motor.htm
-Doug
Postby edhand » Wed 10.08.2005, 19:53
Doug,
Many thanks, I figured it was still around somewhere. :D Printed it all out and ordered a pair of the kits from Dickmans.
Ed
edhand
Postby desmondsee » Thu 11.08.2005, 10:50
how about this problem: one lifts and the other only goes halfway and stays there! both lifts up at the same time though...hmmm....i have already switched out those plasticky parts since and then had no problems on grinding sound but not lifting ...sigh....
at last...
desmondsee
Postby nickb » Fri 12.08.2005, 09:19
Sy did you ever cure your problem because it's happen to me today for the first time, the lights come on but dont rise??? anything obviouse I can check???
nickb
