FRONT LEFT LIGHT DON'T GO UP!!!HELP!
Postby hamleto » Sat 17.03.2007, 14:00
Hi guys,
I have a problem with my left front light, its don't go up!!!
The motor of this light spin free and the light don't go up completely, but chatter in midle position.
Please, help me:(
Tank You
Gian[ITA]
Sorry for my bad English;)
hamleto
Front Left Light Don't Go Up
Postby algirdas » Sat 17.03.2007, 15:35
Dear Gian:
It sounds as if you need to rebuild your headlight motor drive on the left side. I just did both of mine (left and right) recently and it is a fairly easy and inexpensive repair.
The parts you can get from Rodney Dickman in the US. Very inexpensive and they will get them out to you quick. In fact, I think you will pay more for shipping than for the parts. Here is the link:
http://www.rodneydickman.com
Click on the tab "electrical" and dig for it. It looks as if the new kit includes a new gear. All you probably need are the small plastic dowels that fit inside the gear and some gaskets.
ABMotorsport also makes the kits. Here is their link:
http://www.abmotosport.com/Elan_products.html
AB Motorsport is a long time supporter of all things M100 and their gear change cables are really first class (that might be the next thing that goes for you-just kidding).
Next, search this site since pretty much everybody with an Elan has had to do this one time or another. For example, see
http://lotuselancentral.com/forum/viewtopic.php?t=7260
http://www.lotuselancentral.com/forum/v ... php?t=7930
http://www.lotuselancentral.com/forum/v ... php?t=7429
Be sure to look at the third link since Nicola is in Italy and he might be able to walk you through the process or at least answer some questions for you.
And no matter what, don't hesitate to post any questions you may have.
Sincerely,
Algirdas
Noli illegitemi carborundum.
algirdas
Postby hamleto » Sat 17.03.2007, 20:50
Can I buy it: http://cgi.ebay.com/ebaymotors/88-thru- ... dZViewItem
Tank you for your good reply :D
hamleto
Postby kmckmc » Sun 18.03.2007, 01:07
I bought this item. It works.
Cheers,
Elan M100 S2
kmckmc
Postby Ekapol » Mon 19.03.2007, 19:44
You could replace the whole gear but my guess is that you might need just 3 plastic pieces in the middle. The gear itself is quite strong and less likely to break.
If you want -- Rodney website also sell metal version of the same gear -- he calls it "the ultimate rebuild". It might upset the whole setup though -- then the other part will not be as strong, etc. I can't confirm how well they work together -- metal and other pieces.
Just get 3 little pieces in the middle and the new gasket. You might even find it quite enjoyable and want to even do another side for fun. :-D
Ekapol
Postby hamleto » Tue 20.03.2007, 19:11
If I want verify that my headlight gear is damage can I do this without unmount front fender??
Tank You
P.S
I try to contact ABmotorsport, but the email address on the main page is invald,why??
hamleto
Postby Ekapol » Wed 21.03.2007, 01:03
hamleto wrote:If I want verify that my headlight gear is damage can I do this without unmount front fender??
You don't need to unmount the front fender. Just disconnect the link and remove the motor.
Algirdas's post above should have all the information you need. Please let us know again if you run into other problems. Also try ordering from Rodney's site.
Ekapol
