Come in number 34 your time is up!! Help needed on code 34
Postby airzward » Sun 08.04.2007, 14:22
After finally doing the paper clip test on my elan, the Code 34 appeared to me in shining lights....very informative but haven't a clue what it means.......Anyone any ideas.....engine is misfiring slightly and smelling like its burning too much fuel (is the mixture is upset!!)
I did see a coolant temperature sensor post on another forum but cannot find it again.....Please help....
airzward
Postby GeoffSmith » Sun 08.04.2007, 15:05
Check your original thread and follow the link - you'll find that Code 34 is "Manifold Absolute Pressure Sensor (Low voltage / High vacuum)". As a first guess, I'd suggest you check that the MAP connections are good - if it's gone open circuit then it would probably give you this error. If there is nothing obvious, then check down your original thread and give Sy a ring as an ElanScan run will report exactly what the MAP is doing.
Geoff
Postby airzward » Fri 13.04.2007, 17:30
just thought i would update this thread
i wiggled a few wires about under the bonet and behind the glove box and all is fine now, no misfires at all and the engine management light has gone off - must of been a loose connection!
bit of an odd fix but i aint complaining!!
airzward
