Satelite delay on Pop-ups
Postby Brasco » Tue 01.05.2007, 13:58
My pop-ups take about quarter of on hour before they decide to open. Is this the relay?
Where is the pop-ups relay situated?
Thanks,
Ad
This shed does not contain me.
Brasco
Postby TheBard » Tue 01.05.2007, 19:54
Hello,
Do you hear a whole lot of whirring before the pods appear? or have you already rebuilt the lightpod motors and have confirmed it is the relay?
From memory the relay is fixed to the firewall/bulkhead, looks like a small blck box with wires coming from it and is from a late eighties Pontiac Fiero, but make sure it isn't a pod issue first!
Cheers,
Ian
TheBard
Postby Brasco » Wed 02.05.2007, 00:35
well, to be fair mate, it's easier and cheaper to change a relay than a motor, so I thought I'd rule the relay out first, rather than do the motor first. :-)
Brasco
Postby Doug » Wed 02.05.2007, 01:22
He's saying that the pod lift motors fail on the gears within them frequently and are easy to rebuild yourself -- however these give noise and should not cause such a delay as you state and usually only affect one side at a time!
The pod control module is on the engine side of the firewall and could be damaged/bad -- give it a thump and then check the electrical connections to be sure they are not with corrosion -- that could be all it needs is some jiggling and plug-in and out to get the connections working to do the trick.
if not then you could need a replacement module -- SEE HERE FOR MORE INFO
Postby Brasco » Sat 05.05.2007, 14:58
Sorry, I've owned cars with pop-ups before, but I'm still getting my head around the terminology on the Lotus...
Doug wrote:The pod control module is on the engine side of the firewall and could be damaged/bad -- give it a thump and then check the electrical connections
You were spot on Doug, it turned out to be the connections to the pod module. Thankfully the module itself is OK, and now the lights are working fine again :D
Thanks for the replies.
Brasco
Postby Doug » Sun 06.05.2007, 07:23
:smt035
Postby TheBard » Wed 09.05.2007, 01:21
Doug, as always you're a wonder, now go and treat yourself to a :beer:
Me, I'm off for a quick :smt117
Sometimes I just have to get that emoticon into a post, love it!
TheBard
