All interior illumination gone
Postby garymb » Sat 05.05.2007, 15:06
Having same problem as elan man: "...all my panel lamps/illumination have all gone off, when I mean the panel illumination I mean everything like speedo, rev counter, boost gauge, oil pressure, volt meter, temperature gauge and fuel gauge."
I checked he interior lights fuse (ok) and replaced the rheostat but still no interior lights (exactly as elan man). any ideas anyone? :cry:
garymb
Postby Gary » Mon 07.05.2007, 16:15
Open the binacle over the dash and twiddle all the connectors.
The other things that might work (don't know why, but did for me), is to put the interior lights on and then off again
Postby Doug » Mon 07.05.2007, 17:52
I'd say you have checked the right things so far.
you need to get the circuit diagram for the interior lights and troubleshoot it
for example check the lines with a voltmeter and jump 12V to parts of it as needed to see where the problem is
definitely check the ground to the circuit too!!
Postby garymb » Mon 07.05.2007, 19:29
Thanks guys, will try all these things-- if they dont work out I guess it might be the rheostat module.
garymb
Postby Doug » Mon 07.05.2007, 22:44
garymb wrote: if they dont work out I guess it might be the rheostat module.
well, Rheostat is my definite number one suspect, but you said you had replaced the rheostat??? you should definitely check its contacts and resistance values to be sure it is working right !!
Postby GeoffSmith » Mon 07.05.2007, 22:50
The rheostat module (rather than the rheostat, twiddly thing with a knob on the dash) takes the voltage set by the rheostat and puts that voltage on all the lights. Without either working correctly, the lights won't work.
Postby Doug » Tue 08.05.2007, 06:12
well, fu@% me ! I thought they were one in the same :smt017
Postby GeoffSmith » Tue 08.05.2007, 06:13
Nope - it's all electronical these days!
Rheostat Module
Postby garymb » Fri 01.06.2007, 12:10
Turned out it was this (or the lack of one!) It was simply missing in this car (bought from UK sports cars, Kent).
Got a replacement in the Lotus parts sale for £7.20 fortunately as opposed to the normal £120 or so. Everything works fine now.
garymb
Postby GeoffSmith » Fri 01.06.2007, 12:42
:smt023
Postby Gary » Sun 10.06.2007, 12:41
Got the same problem. Tried everything. Lights under mirror work so guess it isn't the fuse ???
How do I know if the rhoestat has gone, and how do I get it out ?
rheostat location
Postby garymb » Mon 11.06.2007, 20:52
I got this from the ever helpful there's only on f in Geof Smith (attached). My rheostat module turned out to be missing completely! When you locate it (you need to get your head down by the pedals and look behind the fascia-- it is one of the larger modules. In my case the replacement module was green, not sure if the original ones were).
I think you have to zero-in on the module as being the problem by a preocess of elimination, fuses rheostat/potentiometer (the dimmer control itself) etc. If it is the module you are in luck as they are in the Lotus parts sale A100M6059F for £7.20 (originally they were £120!) Worth buying one to see if it fixes the problem-- as it's bound to go at some point if it's not the issue right now!
garymb
Postby Gary » Tue 12.06.2007, 09:07
oh, so it is just that box unit then, I presumed it would be the actual switch on the dash that was the problem. I'll have a look at the weekend. Thanks for that
Postby Gary » Sat 16.06.2007, 16:30
Call me stupid, but I had a look and couldn't find this.
So is this the block under the cowel above the steering wheel ? No underneath it ??
Re: rheostat location
Postby GeoffSmith » Sat 16.06.2007, 17:26
garymb wrote:When you locate it (you need to get your head down by the pedals and look behind the fascia-- it is one of the larger modules.
Here's a hint Gary!
Postby Gary » Sat 16.06.2007, 17:29
So it is above the peddles, driver side then? Didn't have much space as couldn't get the car out the garage today 'cos of the rain...
Postby GeoffSmith » Sat 16.06.2007, 17:40
Stuck a mirror down there! I just have and they are mounted just in front of your right knee, right at the bottom. If your hand-eye coordination is good, I reckon you could change it in about 10 seconds with a mirror. :-D
Postby Gary » Sat 16.06.2007, 19:06
I'll have a go next weekend.
I'm not used to putting a mirror down there, isn't that what women are supposed to do ?
Postby Gary » Mon 25.06.2007, 12:49
Right, I've tackled this job today. You diffenetly do need a mirror, and the light module is green.
Being luckier than most I was able to swap the module out of one car into the other and yep that fixed it.
So now just need to order a new module from the parts sale
