by ppete100 » Sun 03.06.2007, 13:50
disconnected battery for recharge recently and after reconnecting central locking decided to throw a wobble.. i'm thinking it might just be dodgy connections but where are the connectors?
pete smith
ppete100
by Sy V » Mon 04.06.2007, 05:39
The connections to the CDL modules, IIRC, are underneath the wing mirrors inside the door.
But, I can't see this being to do with them and tend to think that your alarm/immobiliser has been disturbed by the cut in power.
- LEC Godfather
by ppete100 » Mon 04.06.2007, 18:24
thanks sy, thought about that. alarm and immob fine.. should I disconnect then reconnect again?
pete
ppete100
by RayD » Tue 05.06.2007, 07:16
Pete,
See
http://lotuselancentral.com/forum/viewtopic.php?t=9126
Is the problem with all the central locking or just the remote? Does turning the key, or lifting the button, in either door effect the other lock. When I had a similar problem it was a bad connection in the drivers door.
- Forum Member
by ppete100 » Tue 05.06.2007, 22:21
ray,
remote works fine turning alarm on/off and red light flashes. pressing door button on either side does not effect the othe door ie. solenoids are not working. guess it's time to take a look inside the door for loose connections?
thanks for info
pete
just a matter of interest, can the alarm be left on when the roof is down and doors locked or would movement outside trigger the alarm?
ppete100
by RayD » Wed 06.06.2007, 09:34
Pete,
The alarm can be used with the roof down, as there are no motion sensors fitted.
If neither of the door keys or the door buttons effect the other doors lock under any circumstances, I’d be surprised if the problem was inside the door. It would mean you had suddenly got two bad connections. I presume you have tried every permutation - locking both doors with the key and lifting the inner buttons and so on. If so you need to be looking for something common to both doors.
- Forum Member
by paulwatkins » Wed 06.06.2007, 10:34
Pete, you need to take a look in the Lotus electrical manual
Section MJ.9 and circuit chart 20.
Both of these will help you in locating components and connectors etc and fault finding
Cheers, Paul
paulwatkins
by ppete100 » Thu 07.06.2007, 22:13
thanks Ray and Paul, will get round to checking everything when the weather changes.. rather be out driving than scratching my head over wiring probs.. no sweat opening with key!!
ppete100
