S2 Exhaust
S2 Exhaust
Postby Breed » Mon 01.12.2008, 14:12
Hi
I have a complete S2 exhaust that is available for a donation to the LEC coffers. It was in use until I had my Piper system fitted. It's stainless from the CAT back, not sure about the front pipe but believe it is the original squished type.There was a rattle at highish revs that I believe was the CAT rather than the back box. It was there for about 3 years and I used it as the change up point so I didn't find it too obtrusive. If it is the CAT a long screwdriver and a hammer will cure it and you will have a straight through system :-D . It has been well wrapped up by Piper and I do not want to unwrap it. Prefer it is picked up from Lingfield in Surrey but if not I'm sure something could be worked out.
Bill
Breed
Re: S2 Exhaust
Postby Specky » Mon 01.12.2008, 14:19
and don't forget an S2 back box will fit an SE in the same pos...(I have one fitted to my SE)
The SE back boxes are more expensive too...
Return to Exhaust
