nitroman wrote:Can anyone give me the measurements of the wide oval outlet on the Peco muffler? I want to replace my tip with something similar & will stop by Copeland Welding when I get back.
philip_sloper wrote:If you read my post of 9th October it already tells you that the solution is to remove the inner pipe from the tail section.
TomE wrote:if you'd specifically chosen the oval+inner design you might be disappointed to have it back from PECO as an oval only.
RichyP wrote:Can't quite see, but is the cut tidy or hacked off inside? Did they remove the oval and re-weld it (welds look a little rusty)?
RichyP wrote:I'd prefere to keep the inner pipe as originally this was described as being the technically superior design for gas flow.
JIMBO wrote:Hi and thanks to every one who has helped or contributed to resoving this problem. I'll get mine back to Peco in the spring, it's too cold to mess about under a car at the moment.![]()
Now, any suggestions about how to get rid of the Mother-in-Law ?![]()
Best regards
