Piper Exhausts turbo downpipe development thread
Re: Piper Exhausts turbo downpipe development thread
Postby HJ2 » Mon 25.11.2013, 21:45
In my experience:
21,5 is max porting size with standard flapper
More is possible with upgraded flapper (bigger ring welded to it) But no irl experience myself ;-)
Modifying the downpipe did the trick for me!
Postby ccb056 » Mon 25.11.2013, 22:02
One person has gone out to 22 mm: http://wikilec.9600.org/index.php/Boost_Creep
ccb056
Postby HJ2 » Mon 25.11.2013, 22:17
With heavy boostcreep, the 0,5 mm extra is not gonna help ;-)
Postby surfboardfiller » Mon 25.11.2013, 22:29
Sandra,
You have increased the internal pressure of the engine increased the amount of exhaust gas being forced out, but its trying to get through the same sized hole as a standard factory setup and it can't do it.
It's not a piper issue, you have modified so many parts of the system you now need to step back from them as individual upgrades and look at the system as a whole. The exhaust gasses can't escape quick enough through that tiny waste gate its a bottleneck in the system.
I don't think porting will go far enough, you may need to re bore the waste gate through and machine the lip off the back. Also look into fitting a manual programmable boost controller if you haven't already.
surfboardfiller
Postby HJ2 » Sun 01.12.2013, 19:13
Just finished the first test drive on peters car after the head gasket job and various upgrades!
The setup for the test drive:
The car is S2
Refurbished turbo with ported 21.5 mm wastegate
Stock Memcal (so NO everest yet)
Uprated intercooler
Samco hose to the intake manifold
Stock pipe between air filter and Turbo intake
Stock pipe between air intake and filter
Piper downpipe without any modification (not flowed, no deflector)
Stock exhaust without any modification (so WITH main cat)
With this particular setup there was no boostcreep (thanks to the porting)
Elanscan (results will be posted here soon) showed a slight overshoot of target pressure with peaks up to 0.8 bar. After the peak, the wastegate duty cycle went to 70% and pressure dropped, but the run was too short to see if it stabilized at 0.65 bar.
Since the control system is not real time, a little overshoot seems normal to me, but perhaps someone with more knowledge can shine a little light on this matter.
Hope this helps streamlining the discussion from here peeps!
Postby ccb056 » Sun 01.12.2013, 19:18
Can you attach the Elanscan data?
ccb056
Postby HJ2 » Sun 01.12.2013, 19:21
HJ2 wrote: (results will be posted here soon)
So Yes! :lol:
Postby surfboardfiller » Sun 01.12.2013, 21:01
HJ2 wrote:Just finished the first test drive on peters car after the head gasket job and various upgrades!
The car is S2
Uprated intercooler
Good stuff!
A peak of 0.8 (overboost) is healthy/normal at wide open throttle =/>3000 rpm and should come down to 0.65 Bar after a short period.
(Over 0.92 suggests boost control failure and the injectors will cut after half a second.)
surfboardfiller
Postby HJ2 » Sun 01.12.2013, 21:07
Thanks for confirming that!
Postby ccb056 » Sun 01.12.2013, 22:57
Steve A was experiencing boostcreep and subsequent overboost with a 20mm port.
He also had a 2 in exhaust with the downpipe (Paul Matty).
I do not know if he had a main cat.
It sounds like peter's car has enough restriction with the oem piping and cat to allow the 21.5 mm wastegate to control boost.
HJ, any plans to go with a less restrictive exhaust?
ccb056
Postby rip » Mon 02.12.2013, 14:01
ccb056 wrote:Steve A was experiencing boostcreep and subsequent overboost with a 20mm port.
Steve's Elan is a UK SE, so it will not have a cat.
Postby HJ2 » Mon 02.12.2013, 14:12
Uhmmm... Was the downpipe Paul Matty's? or Piper!
Postby HJ2 » Mon 02.12.2013, 14:13
Plans enough, but waiting for funding :poke:
Postby ccb056 » Mon 02.12.2013, 14:32
HJ2 wrote:Uhmmm... Was the downpipe Paul Matty's? or Piper!
Downpipe was Piper. Exhaust was Paul Matty's.
ccb056
Postby surfboardfiller » Mon 02.12.2013, 16:00
Paul Matty's is a rebrand of something else like Miltek?
surfboardfiller
Postby Peter D » Tue 03.12.2013, 20:45
LEC won't allow ECU files to be uploaded.
Export to Excel gives me an error message : Old format or invalid type library...
So please replace pdf the extention to ecu.
Speed has never killed anyone, suddenly becoming stationary… that’s what gets you.
Peter D
Postby ccb056 » Tue 03.12.2013, 21:25
I was able to export to Excel, see attached.
2013-12-01 Elanscan after HGJ - Copy.xls
Note, to bring the file under the 1 MiB limit I filtered out everything that wasn't 3rd gear 100% throttle.
Also see the attached graph (dual y-axis).
From this elanscan data you have proper wastegate control, which is excellent.
The good news is this is the first documented case of a successful Piper downpipe.
I suspect the success is likely due to the restrictive exhaust (Lotus crimp and catalyst downstream of the downpipe).
Now if we can find some data with someone who is also running a Piper exhaust with the Piper downpipe we can focus on the overboost problem a lot of people are experiencing. Surfboardfiller, how is that coming along?
ccb056
Postby HJ2 » Tue 03.12.2013, 21:29
Good stuff!
That would be my configuration as well :-) However: my piper is 'deflectored' by me!
Don't forget that Peter's car is ported now 8)
Come on guys, get your elanscan out!
Postby Peter D » Tue 03.12.2013, 21:33
ccb056 wrote:I was able to export to Excel, see attached.
Is it my Excel 2007 on Windows 7, or my Elanscan that's causing the error ?
Any tips in how I can make the export work ?
Peter D
Postby ccb056 » Tue 03.12.2013, 21:55
I used the beta elanscan on windows 7 with office 2010.
ccb056
Return to Exhaust
