Torque settings
Torque settings
Postby Paul.P » Thu 15.11.2007, 20:41
Can anyone please tell me torque settings of the 4 bolts & 2 nuts that hold the wastegate manifold to the pre-cat ?
Postby paulwatkins » Thu 15.11.2007, 20:53
Paul, is this diagram any good, or is it the wrong section?
paulwatkins
Postby Paul.P » Thu 15.11.2007, 20:55
Yea, thats spot on Paul !, do you know these settings ?
Postby paulwatkins » Thu 15.11.2007, 20:56
No I just copied the diagram from the manual.
I referenced it when I did my rebuild
paulwatkins
Postby tweetdriver63 » Thu 15.11.2007, 21:03
Paul.P wrote:Yea, thats spot on Paul !, do you know these settings ?
If this is what you're asking, that's lb-ft in parenthesis, and the metric (whatever you guys use) is the other number.
'91 Elan SE
'04 MB C230 Sport Coupe
'08 Mercury Mariner Hybrid
tweetdriver63
Postby Paul.P » Thu 15.11.2007, 21:05
tweetdriver63 wrote:If this is what you're asking, that's lb-ft in parenthesis, and the metric (whatever you guys use) is the other number.
Need the values Chris ?
Postby GeoffSmith » Thu 15.11.2007, 21:29
20.9 lb-ft and 43.3 lb-ft according to the diagram Paul. :wink:
Postby Paul.P » Thu 15.11.2007, 21:53
geoffsmith wrote:20.9 lb-ft and 43.3 lb-ft according to the diagram Paul. :wink:
WAP !, thanks Geoffers, good job your here :!:
Postby Paul.P » Thu 15.11.2007, 22:29
From what i can make out from diagram Geoff, the 6 bolts are all 20.9, do you concour ?
Think the 43's are the bolts which hold the turbo to the engine ?
Postby GeoffSmith » Thu 15.11.2007, 23:59
Yep.
Exhaust manifold to block and turbo housing to manifold = 43
Wastegate plumbing (bit agricultural to be called a manifold Paul!) to turbo and plumbing to precat pre-cat = 20.9
It's now Wiki'd for when I come to do it.
Just noticed that the 'metric' figures are a bit strange, because by my reckoning, 43ft-lbs = 29 N.m not 2.9! :smt017
Postby tweetdriver63 » Fri 16.11.2007, 01:33
Geoff,
This is how the service manual explains the numbers:
kgf.m (lbf.ft)
I'm not sure what the extra "f" is in each (before the dot), but my guess is "force," so pound force per foot, and kilogram force per meter. Sound reasonable?
If so, then 43.3 lb-ft = 19.6kg-ft = 5.9kg-m.
That would seem to agree with the diagram, which has "6.0 (43.3)" for the turbo mounting bolts.
Wow. I'm pretty good. :smt038
(We need a smiley that pats itself on the back)
'91 Elan SE
tweetdriver63
Postby GeoffSmith » Fri 16.11.2007, 09:11
:agree: .... and multiply by 9.8m/s² to convert to Newtons. :smt023
Postby dapinky » Fri 16.11.2007, 11:35
I agree with both the findings and the mathmatics, however, i take exception to the phrase which suggests we on this side of the pond use Metric!!!!
Luckily the British (I can't say English, 'cos the Scotts Dragoons were there aswell) beat Napoleon a few years ago and as such, and being an 'old fart', i still work in Imperial measurements.
I'm quite used to useing a spanner (wrench) and do a bolt up to 25ft.lbs and be happy that it is gonna be very close to the required torque, but i wouldn't have a clue what 15Nm or 1.6Kg.M feels like.
Sorry, I'm :offtopic:
Postby rip » Fri 16.11.2007, 13:24
dapinky wrote:I agree with both the findings and the mathmatics, however, i take exception to the phrase which suggests we on this side of the pond use Metric!!!!
We all use both in the UK.
I expect you will have a metric set of spanners. You should have because most (if not all) of the nuts & bolts in the Elan are metric.
I was brought up fairly fluent in both, and believe imperial to be silly (which I am prepared to debate sensibly in the off-topic section), but I fully understand that to ditch it in favour of metric would be a major, expensive upheaval.
A kg.m is not a true measurement of torque anyway.
:offtopic:
Postby dapinky » Fri 16.11.2007, 13:36
rip wrote:I expect you will have a metric set of spanners. You should have because most (if not all) of the nuts & bolts in the Elan are metric.
.....and believe imperial to be silly (which I am prepared to debate sensibly in the off-topic section)
:offtopic:
Sorry, I am definately Off Topic!
Yes, I have metric spanners etc (and I do understand linear metric) but cannot accept what is silly about measuring distance in cubits, chains and furlongs :roll: )
We all accept horses measured in hands, races in furlongs, distances in miles, pressure in psi, fuel in gallons, milk in pints, beer in the official 'scoop' {which = 1 Imperial pint!}, etc etc etc
I was dismayed when i last bought some timber though.....
....I wanted 2 yards of 4" x 2"........
.....I could only get 2 metres of 100mm x 47mm.......
....and it cost me 3 bob a foot! :smt044
Postby GeoffSmith » Fri 16.11.2007, 14:00
rip wrote:A kg.m is not a true measurement of torque anyway.
Quite right, its kgf.m
dapinky wrote:I was dismayed when i last bought some timber though.....
Not recently then!
Postby Paul.P » Fri 16.11.2007, 17:31
Jesus, & i thought i was old fashioned :!: , now i'm as patriotic a brit as you will get, but come on you old foggies, come into the new millenium !
Postby paulwatkins » Fri 16.11.2007, 19:27
:shock: Crikey! Sorry PaulP for all this! :lol:
I should of added to my initial reply: the units in the diagram are kgf.m (lbf.ft)
:lol: I think you got the answer in the end.
paulwatkins
Postby Paul.P » Fri 16.11.2007, 19:31
paulwatkins wrote::lol: I think you got the answer in the end.
You gotta laugh, ain't ya Paul :lol:
Postby Dico » Fri 16.11.2007, 19:37
Paul.P wrote:Jesus, & i thought i was old fashioned :!: , just take a look at my shoes at Donington in march!
Yep, old fashioned and BIG! 8)
Return to Exhaust
