Whacked my exhaust !!
Postby simonbuk » Sun 09.10.2016, 11:02
After a cruise around the Peak District I whacked my exhaust a couple of times on some very bumpy roads. Its flattened the front section as it comes down a bit. Also hit the sump - looks like I was lucky not to have done more damage.
Would this restrict performance ? Can't notice anything I have to say, I'm sure there are other cars out there with slightly squashed pipes ?!
I have no oil leaks so is it ok to leave the sump ?
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Re: Whacked my exhaust !!
Postby simonbuk » Sun 09.10.2016, 11:13
And whats the braided covered bit ? Is that a pre-cat ?
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Postby HJ2 » Sun 09.10.2016, 11:55
The braided part is the flex section :D
As long as you don't have a leak in this section, I see no reason not to continue using this exhaust section.
What could be worrying (from my own experience unfortunately):
When you hit the bump, all cast iron parts upstream could be damaged! : Pre-cat housing, downpipe, and exhaust manifold!
So check for any evidence of sooth... :bonk:
Postby Simon_P » Sun 09.10.2016, 14:29
All pretty normal. After a while you can spot the dips that are going to cause the imminent scrape.
As H2J says this is probably why all of the turbo exhaust manifolds I have seen are cracked.
Postby simonbuk » Sun 09.10.2016, 14:34
Ok cheers, thought it might all be pretty normal for an underside of an Elan !!
Wheres my pre-cat then - further ^up the pipe that has been scraped ?
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Postby HJ2 » Sun 09.10.2016, 15:43
You got it! :bonk:
Postby steve matthews » Sun 09.10.2016, 16:23
Looks like a Normal M-100 Exhaust.
Steve
steve matthews
Postby Simon_P » Sun 09.10.2016, 21:38
simonbuk wrote:Wheres my pre-cat then - further ^up the pipe that has been scraped ?
behind the front heatshield - The one with slots in it.
Postby simonbuk » Sun 09.10.2016, 22:09
So it looks like I only have a pre-cat then - is that right ?
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Postby Brit-Car-Nut » Sun 09.10.2016, 23:09
If you have an S2, it should have a Cat as well as a pre-cat.
Postby Simon_P » Mon 10.10.2016, 01:52
The main cat is attached to the pipe - the flange in the picture has it at the other end of the pipe, it will be behind the prongeron.
It looks like you have a Piper system which came with or without a cat or even an extra silencer.
Postby Kathryn » Fri 15.06.2018, 20:10
Whilst looking at my exhaust to try and help Simon in his latest thread I discover this!
After reading here, I guess it’s ok?
(I must say my sump is horrendously dented - far worse than Simon’s! No leaks though and I don’t think it’s recent damage.)
Palacio S2 #540
Kathryn
Postby simonbuk » Fri 15.06.2018, 20:21
Thank you for looking !! Mine looks worse than that and there were no leaks/damage afterwards. I think a few must look like that !!
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Postby muley » Sat 16.06.2018, 06:25
FWIW ~ all my Elans looked worse than that..
Postby CalElan » Fri 29.06.2018, 00:21
there's already a fairly flattened section as the exhaust passes over the prongeron.
CalElan
Return to Exhaust
