Are these going to fit my car ?
Postby simonbuk » Fri 19.01.2018, 13:00
With my head soon to be replaced things are obviously coming off so i want to do as much as possible whilst i'm there.
Are these two items correct for my car ? Will they all fit together nicely ?!
http://www.piperexhausts.co.uk/pipersto ... pgafqbit76
http://www.piperexhausts.co.uk/pipersto ... ts_id=4829
Bit confused as the pre cat elinmiator says suitable for 2 1/4 inch systems.
The down pipe says its made from 2 1/2 bore ?
Which comes first the pre cat elinmiator or downpipe ?!
I have the Piper 2 1/4 system with sports cat fitted.
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Re: Are these going to fit my car ?
Postby dapinky » Fri 19.01.2018, 13:45
Simon,
You don't need both of these - it's one or the other!
It becomes a bit clearer if you consider the time-line history (which is easy for me to say, 'cos I was involved in it from the start, but not necessarily so clear to anyone who hasn't been here for 10 years or so, so it is no disrespect intended to yourself).
Originally, the exhaust was a 2" pipe all the way from the front pipe to the back of the car - then a couple of aftermarket suppliers replicated the OE in stainless steel.....
... then along came Peco with a 2 1/4" stainless system - this released extra power, but had a 'noise' which some found annoying....
.... then Piper wanted to make a 'modular' system so people could have what they wanted/needed - initially it was a choice between 2 1/4" & 2 1/2" pipework...
.... as a result of a request from someone on here, the PCE was developed to replace the cast iron 'dustbin' above the front pipe - the OE part is both heavy and restrictive - not noticed with the OE exhaust, but once a freer flowing system was introduced, the other parts became restrictive to the overall result...
... then the downpipe was introduced to replace the whole cast-iron stuff from the turbo backwards - more weight saving and efficiency - but basically also replaces the PCE...
... then Peco was taken over by Cybox, and their system was modified to reduce the 'drone'...
...and then they offered an extra silencer...
...and so it goes on.
What I would say is that if you currently have a 2 1/4" piper system, a PCE will give you an improvement (as would the whole downpipe), but they would both give a very similar improvement - but if you have a 2 1/2" system, the downpipe will give more improvement to a PCE.
Whichever way you decide to go, make sure that you have plenty of spare change for the swearbox - getting all the bolts which hold the PCE to the topbox out can be "fun".
Postby bbjon » Fri 19.01.2018, 20:37
I literally fitted the downpipe yesterday - I can heartily recommend it! It's a little louder but the car spools more quickly. It's also massively lighter and easier to fit. Piper claim it will only work with their exhaust but it happily bolts up to the cybox/peco. You do lose all the heat shields but with the current temperatures what does it matter!
bbjon
Postby simonbuk » Sat 20.01.2018, 18:43
Thanks Dave - thought i was getting unnecessarily confused! !
So, (hopefully) what you are saying is you either buy the PCE which bolts onto the existing downpipe, or buy the new improved downpipe which replaces both ? :smt017
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Postby roy666 » Sat 20.01.2018, 18:53
Sounds great. Is this on the SE? I've got a S2 and I've been told if the pre-cat is removed then the car will not pass the MOT emissions test. I've got a PNM exhaust... so no main cat (box) on the system. Can an S2 pass the MOT without any cat on it then?
roy666
Postby simonbuk » Sat 20.01.2018, 18:57
It is on an S2 yes. I thought being over 20 years old the pre cat would be pretty much useless anyway ? I've got a sports cat in the main part of the exhaust.
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Postby Simon_P » Sat 20.01.2018, 19:25
The pre cat is to comply with the law rather than the MoT test.
When the engine is cold the main cat hasn't warmed up to its "light off " temperature and isn't effective.
The pre cat being close to the manifold heats up faster and compensates.
With the engine hot and the main cat working you should pass the MoT test.
Tested to the correct standard with a strict tester. The sports cat is marginal. You may need a warm up drive if the car has been idling.
If you remove the pre cat you may pass the MoT but may not comply to laws regarding construction and use.
Postby dapinky » Sat 20.01.2018, 21:38
simonbuk wrote:Thanks Dave - thought i was getting unnecessarily confused! !
Simon, basically, yes - but a picture will save me writing the rest of the thousand words.....
The PCE replaces item number 53.
The complete downpipe replaces number 53 and number 36
Postby simonbuk » Sat 20.01.2018, 22:37
ok great, understand now thanks.
And Piper got back to me confirming i could purchase just the PCE without the cat, its just their website that doesn't allow it !!
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Postby HJ2 » Fri 09.02.2018, 14:35
I just came acros this:
https://www.jaguarforums.com/forum/xf-xfr-x250-44/xf-3-0-sport-magnaflow-exhaust-helmholtz-resonator-191691/
Did anyone ever tried to add a helmholz resonaor to a PECO exhaust in order to get rid of the drone noise?
Sounds doable, but need to check if there is space at all for this...
Postby GeoffSmith » Fri 09.02.2018, 15:50
I've often wondered what the acoustic equivalent of the Zobel network/Boucherot cell looked like…
Postby simonbuk » Fri 15.06.2018, 11:00
Well the PCE eliminator has been fitted and failed it's MOT. It's half a per cent out in emissions. I 'believe' I have a sports cat in my exhaust but unsure what it is exactly.
I need to know what it is exactly before I proceed, my MOT man thought it was just a silencer. If he knows it's a cat in there he will try some other things to get it to pass.
Sounds like I might have f*cked up and need to put the pre-cat back in place !!
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Postby HJ2 » Fri 15.06.2018, 13:58
simonbuk wrote:Well the PCE eliminator has been fitted and failed it's MOT. It's half a per cent out in emissions. I 'believe' I have a sports cat in my exhaust but unsure what it is exactly.
From a flow point of view I would rather put the main cat back, not the pre-cat! (assuming you are cat-less, like me)
The first few years cat-less my car past MOT, but ony just.
Then suddenly there was a change (what? Vacuum leak?) and the CO increased 0.5, MOT fail.
Then i found a loophole in the regulations. Due to the loophole my car is allowed to be measured to open loop standard, so 2,5% CO2. They unplug the O2 sensor and presto! pas with flying colours.
I need to test my CO2 after repairing the vacuum line, perhaps it is back to closed loop pass values again :D
Can you stick a camera in that thing?
Looks more like a Cat then a silencer to me. Perhaps it was a cat once but it's emptied?
Postby Kathryn » Fri 15.06.2018, 19:20
Simon, my car has one of those and I have a Piper with sports cat.
Palacio S2 #540
Kathryn
Postby simonbuk » Fri 15.06.2018, 19:28
Kathryn wrote:Simon, my car has one of those and I have a Piper with sports cat.
So is that the sports cat ?! Just trying to clarify exactly what it is.
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Postby simonbuk » Mon 18.06.2018, 14:35
Had it confirmed from Piper that it is indeed the sports cat.
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Postby Simon_P » Mon 18.06.2018, 15:25
Can you post the emissions results?
How old is the fuel? Is it cheap stuff or high octane? Brand?
How hot was the engine fans coming on?
Did you drive it hard before the test to get it hot?
Postby simonbuk » Mon 18.06.2018, 15:32
Haven't got the results I'm afraid. My MOT man says its either half a per cent too high or currently at half a per cent (can't remember which !), and needs to get it down to 0.33. sound right ?
He said he let it get nice and hot so the fans were coming in. Had standard fuel in it when I left it end of Feb.
He said he's got some chemicals he can add to see if that helps.
Watch this space.....
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Postby Simon_P » Tue 19.06.2018, 02:06
CO should be max 0.5 at idle and 0.3 at 2500 rpm.
If it is 0.5 and it should be 0.3 you are miles out. If its 0.33 and needs to be at 0.3 a spirited drive before testing would probably do it - The cat needs to be hot and the oil needs to be at 80°C for the test which they might not be if the car has been idling for a while.
Postby simonbuk » Tue 19.06.2018, 03:54
You asked about the type of petrol being used, would that make much of a difference is I put some expensive stuff in ?
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Return to Exhaust
