Exhausts | Genuine exhaust parts
EXHAUST DOWN PIPE (Series 2) A100S6019F EACH
40.35
EXHAUST DOWN PIPE, (Series 1 Turbo ) C100S0023F EACH
56.79
EXHAUST FRONT PIPE (Series 1 with catalyst) B100S0061F EACH
44.85
REAR SILENCER (Turbo non Cat) (Lotus) J100S0008F EACH
187.30
Exhausts | Manifolds
EXHAUST MANIFOLD A100E6166S EACH
151.49
GASKET, EXHAUST MANIFOLD to HEAD A100E6097S EACH
12.03
Exhausts | Orginal lotus exhaust parts
EXHAUST CENTRE SECTION (Series 2) With catalist fitted. A100S6023F EACH
58.65
INTERMEDIATE PIPE (Lotus) For all non-catalyst cars. C100S0007F EACH
30.75
Exhausts | Stainless steel exhausts
CENTRE SECTION (Turbo, non-cat) SJ100S0003 EACH
37.21
FRONT SECTION (Turbo, non cat) SJ100S0004 EACH
44.58
REAR SILENCER (Non turbo) St/St SJ100S0007 EACH
100.61
St/St 'SPORTS' REAR SILENCER SJ100S0006 EACH
98.68
STAINLESS STEEL SYSTEM (Turbo, non-cat) SJ100S0005 4 piece
231.00
+vat
woody wrote:Neil,
Where are you getting the 2 1/4" system fitted.
Woody
Requirements for a Successful Installation....(of ESM Chips)
Sports exhaust fitted (greater than 2 inch diameter)
If you have a large bore exhaust fitted (>2" bore) and suffer with boost creep this upgrade will not cure it. However, if an MBC was employed then its removal may have corrected the issue. It is advisable to check the hoses to the BSV for leaks thoroughly and to ensure unions are fully secured. Remember this line is pressurised under boost so the seals must be good. Test-drive the car to see if the creep has been resolved before fitting the chip. If boost increases beyond 0.95 bar then fuel cut will still occur with the chip and you should consider porting the wastegate, putting a constriction in the exhaust and whether its worthwhile installing the chip.
