Stainless, big-bore exhaust
Postby Abington » Tue 05.12.2006, 16:39
|don't know whether my previous question/problem has or will be posted on the forum. I was asking about big-bore exhaust sytems, where to get same, how much to pay and what to do about the over-boost problems that can occur after fitting.
I have since been told that big-bore systems make SE Turbos run like s**t and all that is needed is a Sports system which has a much less restrictive silencer. This, apparently, allows much better breathing and so 'job done'!
Does anyone out there have any experience/comments?
One swallow may not make a summer but it would certainly make your day!
1971 Elan +2 S130/5 JPS (150bhp @ wheels)
1987 Excel SA
1991 Elan SE T urbo
Abington
Postby Sy V » Tue 05.12.2006, 16:46
Moved from "Forum Questions/Problems"
Postby Nige » Tue 05.12.2006, 17:03
Not sure why anybody would tell you that an SE would run badly with a big bore exhaust as my and I believe the general view around here is that going from the stock 2" exhaust to a 2.25" or a 2.5" is of significant immediate benefit in terms of performance gains and also an essential pre-requisite if you want to get the maximum benefit from other performance enhancers such as one of ESM's chips or even the 'old fashioned' manual boost control. Just going to a sports exhaust still leaves you with a 2"restriction for the majority of the system. If you enable the engine to boost more you have to give the gasses a means of escape, ie match the increased input by increasing the available output. Boost creep is a possibility with a bigger exhaust and yes it's a pain if you hit the fuel cut off because of this. The solution however is straightforward, for the majority of people the increased fuel cut off level in an ESM chip means that when it is combined with a big exhaust fuel cut off is unlikely (I have no problem with that combination). A guaranteed solution is to port the wastegate to ensure it can flow enough exhaust bypassing the turbo. As far as availability of large diameter exhausts for an SE go you would be hard pressed to find a more cost effective option than the PECO system described at length elsewhere on the forum.
Back in Blighty
Nige
Postby theelanman » Tue 05.12.2006, 17:12
Big-bore stainless exhaust
Postby Abington » Sun 10.12.2006, 21:53
Nige,
Thanks for advice. Have spoken to PECO already but they sold out prior to end of November price increase! Have to wait for new run.
Will speak to Alan (?) re chip in due course. Which one did you say you have? Also, do you know what is involved in porting the wastegate?
1987 Excel SA
1991 Elan SE T urbo
Abington
Postby theelanman » Mon 11.12.2006, 01:24
Ab
dont know where you are in the country......but I had one custom made with straight though silencer in 2.25" stainless for £275 in macclesfield cheshire...it was pre peco but there have been a couple of other who've had it done at the same place...its all they do.....design exhaust systems for race cars......
theyve got rid of the squish and it doesnt over boost....
dont know how or why but the sound is a dream.....
I even got accosted at several service stations in the uk and france on the way to LM asking what it was abd where I got it coz it makes a really sweet sound when you stick your foot down
cheers
G
ps drop me a pm if youre near cheshire/macclesfield and I'll give you the info....if not sorry for temping you!!!!... :-D
Postby GeoffSmith » Mon 11.12.2006, 09:17
Gareth,
How close is Devon to you?
Geoff
Postby theelanman » Mon 11.12.2006, 09:57
hundreds of miles..... :roll:
Postby Siegreen » Wed 13.12.2006, 16:56
Had my PECO fitted today, very nice sound not too loud (was a concern didnt want to sound like a chav), and no sign of overboost so far although havent had much of a chance to give it a full test yet just drove straight back home (via a few twisty roads!! :-D :-D ).
Dave jones, (friendly and knowledgable bloke) thanks very much. See you at Donington.
I fart in your general direction! You mother was a hamster and your father smelt of elderberries!"
Azure Blue S2 No. 452
Siegreen
Postby Exbury » Fri 05.01.2007, 19:20
I had a custon 2.25" job fitted in Essex, the car immediately improved significantly in power and sound, unfortuantely not driven it much since =(
Too many other goodies to fit and not enough time!
Exbury
Return to Exhaust
