Had new drive shafts about 2000 miles ago, new calipers, discs, dampers - it did it before they were fitted, I am puzzled
not too bothered but theres something loose some where - longeron, gearbox mount? Any ideas?
not too bothered but theres something loose some where - longeron, gearbox mount? Jeemy wrote:I am sorry if this sounds patronising - its really not meant to be! Have you checked the seat bolts? I tried for ages to track down a clunk at exactly this point, reversing onto the driveway. It was the seat bolt which was loose; the bolt clunked to the opposite pole on a dead stop and because the whole car stops/rocks, you don't feel the movement, which is slight anyway.
nicowalker1 wrote:I also get a clunk when first applying the brakes in reverse.....
dapinky wrote:nicowalker1 wrote:I also get a clunk when first applying the brakes in reverse.....
I think that's just a blue car reversing into you while you try to get away![]()
nicowalker1 wrote:I also get a clunk when first applying the brakes in reverse. It is just a small abount of play in the pads...
There should NEVER be that much play in the fit of a pad!
