Replacing window switch
Postby nissias » Sat 21.09.2019, 22:03
Hi guys,
My driver's window is not working and I suppose the switch might need to be replaced. Does anyone know how to do this myself?
I would appreciate some guidance.
nissias
Re: Replacing window switch
Postby maz_r » Sun 22.09.2019, 18:53
Replacing the switch is simple; gently prise it out of the centre console, unplug the wiring harness underneath and then plug in your new one.
The difficultly is finding a working replacement switch...
To prove if it *is* the switch, you can try unplugging both switches and using the working one on other side - they are identical on both passenger & driver side.
maz_r
Binary Bodger
Postby JusNoGood » Wed 25.09.2019, 17:50
Have you tried working through the guide?
viewtopic.php?f=32&t=20999
My window didnt work and just turned out to be rusty connectors to the window motor
JusNoGood
