by Lotussi » Fri 31.01.2020, 09:47
Hi again,
I have more loose ends,
photo taken from underneath the car
the red wire...
What is this for?
Lotussi
- Tinkerer
by Simon_P » Fri 31.01.2020, 22:31
Probably the A/C compressor clutch - should be tiewrapped to the coolant hose.
You have the old type PAS hose - you should check them and for piece of mind change them as they have a tendency to come off.
by Lotussi » Wed 05.02.2020, 11:24
Hi Simon_P
Thank you
Lotussi
- Tinkerer
