David_F wrote:my temp gauge never gets above the first mark (is this normal?)
ShaunM wrote:… gentle 50mph cruising it can drop as low as half way to the first mark…
GeoffSmith wrote:ShaunM wrote:… gentle 50mph cruising it can drop as low as half way to the first mark…
I suggest you check that your thermostat isn't stuck open.
ShaunM wrote:GeoffSmith wrote:ShaunM wrote:… gentle 50mph cruising it can drop as low as half way to the first mark…
Was expecting someone to post that. Had this discussion with other established LEC members a few years ago. Definitely not stuck open as would drop to zero in winter which did happen one year when a thermostat failed and stuck open. I've had 3 thermostats in 13 years of owning the Elan and all do the same when cruising at 50mph on very low throttle. You should try it...5 miles on "rolling road" throttle (and before you ask, yes I've fitted the correct themostat, the last one was fitted by Long Stratton Lotus when they fitted the new radiator)
Not sure who your "local Lotus specialist" is but with that list I'd be a bit wary.David_F wrote:no issues needs both rear wheel bearings, front upper ball joint, new track rod ends and a new sump after being grounded out at some point.
