Pump
Pump
Postby senftarnaud » Mon 27.08.2012, 19:40
Hello,
I wanted to know what is the pump in the bottom right of my picture because it never lights on my vehicle.
(Translated with google)
Thank you in advance and good day
senftarnaud
Re: Pump
Postby Specky » Mon 27.08.2012, 20:32
The pump in question is the electric water pump.
The pump only works when the engine is off, this is because it pumps coolant in the opposite direction to normal.
To check if this pump operates correctly, start the car and let the engine heat up until the electric fans cut in. (20 mins or more) The moment they start, turn off the ignition. Run round to the front of your car and place your hand on the motor, you'll feel it vibrating. Run back round and restart the car. Take her for a quick drive to cool her back down.
As a rule the electric pump is very rarely used.
Re: Pump
Postby senftarnaud » Mon 27.08.2012, 21:09
Thank you alot for your reply.
I see that you are familiar with.
Good night and see you soon
senftarnaud
